1 Reply Latest reply on Oct 23, 2006 4:59 AM by ggshow
    Using PolyStar tool
    camomiletea
      I'm unable to select additional options (such as PolyStar) for the Rectangle tool, which should appear when you click on the lower right corner. They don't appear. I have an educational version of Flash MX 2004, on Windows XP Home. Has anyone encoutered the problem? How to fix this? Is there any other way to access that tool?
      Thanks!
        • 1. Re: Using PolyStar tool
          ggshow Level 2
          1)
          do you see a small triangle at the lower right corner of your rectangle tool?
          if not, the polystar tool might not added to your tools panel.
          you can check it through menu
          Edit - Costomize Tools Panel
          make sure the polystar tools is added to the box where rectangle tool located.
          2)
          check if you got these 3 files (PolyStar.jsfl PolyStar.png PolyStar.xml) in the following folder:
          C:\Documents and Settings\user\Local Settings\Application Data\Macromedia\Flash 8\en\Configuration\Tools
          *username is the current user account you logged in on your pc
          if any of files above doesnt exist, it might not installed properly,
          try copy the files from:
          C:\Program Files\Macromedia\Flash 8\en\First Run\Tools
          to paste at:
          if you cant find it from:
          try copy from other computer
