2 Replies Latest reply on Jan 9, 2009 10:18 AM by DMGETPA
    Project Files Not Deleted From Server
    DMGETPA
      Thank you in advance if you can help.
      Application: Robohelp6/Server6 and earlier versions. Don't know about 7 or 8.
      Output: Webhelp Pro
      Background: Whenever I delete a topic from the publisher and publisher a project to our server, the htm file for that topic is not deleted. I started calling them "ghost" files because they should be dead and gone. Some users access these files following a direct URL hence providing them with outdated information. They don't normally appear in the application search results but hyperlinks to them work until the file is removed.
      I've tried different publishing options to get them removed. Check for delete files and republish entire project. The only way I found to get rid of them is to delete the file from the server manually. Another option is to delete the project from the server and republish everything.
      Question: Can anyone explain what is going on and if there is something I can to make sure they are automatically deleted when publishing.
        • 1. Re: Project Files Not Deleted From Server
          Welcome to our community, David
          I don't believe anything in RoboHelp publishing will actually ever delete files. It's my experience that any file that needs to be removed from the server has to be accomplished manually.
          So I know this calls into question what exactly does the option "Check for deleted files" actually DO?" Am I right?
          Here's the deal. Upon publishing, a list is created. The first round takes longest as it is also creating the list. When you publish again, files are compared to the list.
          Need updating? Nope. Skip it and move on.
          Need updating? Yes. Copy and replace the file.
          The option to check for deleted files slows the process. The process then becomes:
          Need updating? Nope. Does it still exist on server? Yes. Skip it and move on.
          Need updating? Nope. Does it still exist on server? Nope. Copy the file and move on.
          Hopefully that helps you better understand what is happening.
          Cheers... Rick
          • 2. Re: Project Files Not Deleted From Server
            DMGETPA Level 1
            Hi Captiv8r,
            quote:
            I believe the above quote answers my question. I guess I was looking for confirmation on what I was seeing.
            Thank you very much for your help.
