1 Reply Latest reply on Oct 23, 2006 1:44 PM by Roger N
    Help window sizes
    kewal_tech Level 1
      Working in RH HTML,
      Generating webhelp and webhelp pro manuals.
      I wanted to know how can we define the size of the help window that opens once the help runs?
      I was able to able to define a customised help window under "Window" but am not able to select this window when I try and configure Source output - webhelp/pro.
      Though am able to select this window when I want to create a .chm file.
      Also, I wanted to know if there a way that we can restrict the size of the TOC window? Similar to what RoboWizard has. ;).
      Thx for your help
      Have a grerat weekend
        • 1. Help window sizes
          Roger N Level 2
          Kewel -
          Brute force method would be to simply search for the frameset file that contains the phrase "220,*", and change those values to a width you do want, as a startup size. If you want to actually 'restrict' the maximum size, you will need a bit of scripting for that.
