3 Replies Latest reply on Oct 18, 2006 5:26 AM by marcusw1234
    XML.load - specifying port in the path
      I have stumbled across a problem when loading XML via an external address using Firefox. Sample code is displayed down the bottom.
      This works fine in all browsers. However, if I modify the target path to include a port number (even the default port 80), it doesn't work in Firefox. It works normally in IE.
      So the path could be: " http://www.mydomain.com:80/test.xml", and it won't work in Firefox. No response.
      Does anyone have any suggestions how to overcome this problem in Firefox? I need to be able to specify different ports (I just used port 80 as an example).
