1 Reply Latest reply on Oct 17, 2006 11:44 AM by aBill
    HTTPService Login system
    Omnipitence
      Hi I was just wondering if any one could help me out with this, i am trying to create a user login sytem using the HTTPService that passes username & email to the server and returns the users details, from which i can then log them into the flex system. I have managed to set up the sending of the data and returning of the user data into a data grid, however when i try to extract just one element from the returned XML data i cant seem to move down the nodes my xml is returned in this format ::
      <rss>
      <channel>
      <title>UserLogin</title>
      <item>
      <id>1</id>
      <userLevel>1</userLevel>
      </item>
      </channel>
      </rss>
      Im trying to pass the userlevel data into a actionScript variable is there anyway to do this?
      And here is my MXML file::
      <mx:VBox xmlns:mx=" http://www.adobe.com/2006/mxml" width="160"
      horizontalAlign="center" cornerRadius="10" borderStyle="solid" borderThickness="1"
      backgroundColor="#c0c0c0" dropShadowEnabled="true" >
      <mx:Script>
      <![CDATA[
      import mx.controls.Alert;
      import mx.rpc.events.ResultEvent;
      import mx.collections.ArrayCollection;
      [Bindable]
      private var loginData:ArrayCollection;
      private function loginDataHandler(event:ResultEvent):void{
      loginData = event.result.rss.channel.item;
      </mx:Script>
      <mx:HTTPService id="loginRequest" url="PHP/Login.php" method="POST"
      result="loginDataHandler(event)">
      <mx:request>
      <userName>{userName_txt.text}</userName><password>{password_txt.text}</password>
      </mx:request>
      </mx:HTTPService>
      <mx:Label text="LOGIN"/>
      <mx:TextInput id="userName_txt" width="140" text="UserName"/>
      <mx:TextInput width="140" id="password_txt" text="Password" displayAsPassword="true"/>
      <mx:Button label="Login" id="login_btn" click="loginRequest.send()"/>
      <mx:DataGrid id="loginAuth" dataProvider="{loginRequest.lastResult.rss.channel.item}
      " width="150" height="71">
      </mx:DataGrid>
      </mx:VBox>
      If anyone can tell me how to pass variables from the returned XML into actionsript that would be great as i can probably work it out from there.
      Absolutely any help or ideas would be great.
      Thanks in advance
        • 1. HTTPService Login system
          aBill
          By default the HttpService deserialize return xml as object. Setting datagrid.dataprovider to an object won't work. It takes array or arrayCollection.
          loginRequest.lastResult.rss.channel.item is an object
          <item>
          <id>1</id>
          </item>
          if you want to show it on datagrid, you can do this
          dataProvider="{[loginRequest.lastResult.rss.channel.item]}
          instead of
          William Chan
          From AS doc
          resultFormat property
          resultFormat:String [read-write]
          Value that indicates how you want to deserialize the result returned by the HTTP call. The value for this is based on the following:
          Whether you are returning XML or name/value pairs.
          How you want to access the results; you can access results as an object, text, or XML.
          The default value is object. The following values are permitted:
          object The value returned is XML and is parsed as a tree of ActionScript objects. This is the default
