4 Replies Latest reply on Aug 28, 2007 12:18 AM by Marc de kwant
    Flex 2 / Java
    m_hartnett Level 3
      I am creating an application that will use Flex2/Data Services and Java/Spring. Communication will be via RPC.
      I will be using Eclipse with the Flex2 plugin.
      Should I create 2 separate projects. One for Flex and one for Java?
      Can the source code for the Flex part and Java part be in the same directory structure or should I contain each project separately and deploy each project separately?
      I haven't been able to find any info on this so if you can point me to some I would appreciate it.
