3 Replies Latest reply on Oct 18, 2006 7:59 PM by Newsgroup_User
    How to distribute to frames for animated gifs
    dz1
      I am making animated GIFs. I need to know how to import an image into the frames that I have and then transfer them to selected images. I know how to do it one at a time, by copy and pasting into each frame, but that is very tidious and time consuming. Is there a way to just do it all with one command? Thanks in advance.
        • 1. Re: How to distribute to frames for animated gifs
          Level 7
          > in advance.
          Are you saying that you want the SAME image in every frame? If so, put
          it on its own a layer and set the layer options to share across frames.
          Make sure only elements you want in EVERY frame are in this layer.
          If you want several images brought in one file, each in its own frame.
          Go to File Open, select all your images and choose "Open as Animation"
          This will put one image file on each frame.
          Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
          Extending Knowledge, Daily
          http://www.communityMX.com/
          CommunityMX - Free Resources:
          http://www.communitymx.com/free.cfm
          .:Adobe Community Expert for Fireworks:.
          news://forums.macromedia.com/macromedia.fireworks
          news://forums.macromedia.com/macromedia.dreamweaver
          • 2. Re: How to distribute to frames for animated gifs
            dz1 Level 1
            Can you type out the step by step instructions for this please. I tried, but I did not get it to work. Thank you..
            • 3. Re: How to distribute to frames for animated gifs
              Level 7
              Well if you can answer the question about what exactly you're trying to
              do, I can.
