2 Replies Latest reply on Jul 7, 2006 1:42 AM by JeevM
    loading images
    JeevM
      hello all,
      I need to fill a button with an image on page load and when i click on that button i need to load a movieclip with that image.
      Can anyone suggest a solution.
      Regards,
      jeevm
        • 1. Re: loading images
          Level 7
          Assuming images are all loaded dynamically.
          Using a blank MovieClip for loading external images or swfs is a typical
          route. You will need a thumbnail and full version of the image.
          For the button, you just need to determine where the blank MovieClip for the
          button is to go: inside a MovieClip button you are making or as a MovieClip
          in a Button symbol.
          Then the button would launch the loading of the full image into another
          blank MovieClip. Your options are the MovieClip.loadMovie method or the
          MovieClipLoader class.
          MovieClip.loadMovie:
          http://livedocs.macromedia.com/flash/8/main/00002479.html
          MovieClipLoader the onLoadInit is a good example.
          http://livedocs.macromedia.com/flash/8/main/00002545.html
          Lon Hosford
          www.lonhosford.com
          Flash, Actionscript and Flash Media Server examples:
          http://flashexamples.hosfordusa.com
          May many happy bits flow your way!
          "JeevM" <webforumsuser@macromedia.com> wrote in message
          news:e8im2e$q24$1@forums.macromedia.com...
          > hello all,
          > Regards,
          > jeevm
          • 2. Re: loading images
            JeevM Level 1
            Thank you So much.
