1 Reply Latest reply on Oct 18, 2006 8:19 AM by Peter Lorent
    smaller components file size
    jonnybennett Level 1
      Is it possible to for example strip down the file size of the combo box component. I don't really understand why they create such a lot of filesize to your swf. Surely there is a way to make them closer to 1k in size?
        • 1. Re: smaller components file size
          Peter Lorent Level 2
          The component needs the V2 Component framework of classes to function (the second component you add to your movie adds much less weight). The only way to save on bytes is probably to skin the component but will that save much? I guess not. You can build your own combobox and you might be able to get to 15k in size. 1k would be amazing and probably worth an entry in the Guinness Book of Records.
