2 Replies Latest reply on Oct 25, 2006 6:09 AM by GaryThompson76
    Invalid AMFX packet error
    GaryThompson76
      Hi I'm testing FDS under Tomcat on Https with a self-certificate
      and i'm getting this error message
      [MessagingError message='Invalid AMFX packet. Content must start with an <amfx> node']
      at mx.messaging.channels.amfx::AMFXDecoder$/::decodePacket()
      at mx.messaging.channels.amfx::AMFXDecoder/decode()
      at ::HTTPMessageResponder/completeHandler()
      at ::ChannelRequestLoader/::callEventCallback()
      at ::ChannelRequestLoader/::completeHandler()
      at flash.events::EventDispatcher/flash.events:EventDispatcher::dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at flash.net::URLLoader/flash.net:URLLoader::onComplete()
        • 1. Re: Invalid AMFX packet error
          Peter Farland Level 3
          Looks like you're contacting a destination that is using the SecureHTTPChannel (and note this would be the HTTPChannel for HTTP). This channel (and it's HTTP equivalent, HTTPChannel) use an XML format to send strongly typed information between the client and server... something we call AMFX (Action Message Format over XML).
          It looks like the response was invalid AMFX... perhaps the client received a server error formatted as HTML instead of a correctly formatted AMFX response?
          Is the problem occuring in MSIE? If so, have you tried adding the add-no-cache-headers property to the secure http channel-defintion in /WEB-INF/flex/services-config.xml?
          <properties>
          <add-no-cache-headers>false</add-no-cache-headers>
          </properties>
          Note any change to the services config would require you to restart the web application.
          Also, have you tried browsing to the channel endpoint to check if it exists? Can you try using an HTTPS sniffer like Paros Proxy registered in the browser to intercept the traffic to see what was wrong with the response?
          • 2. Re: Invalid AMFX packet error
            GaryThompson76 Level 1
            We've switched Servers to a https with a propper ssl certificate not a self-certificate,
            but same problem, I think it's a configuration problem with the messagebroker or https.
            the app works perfectly under http, but we need the https.
            If I visit my app using IE I get this error
            https://orappsrv1.ad.hull.ac.uk:8443/flex/GetStudentDetails/GetStudentDetails.swf
            [RPC Fault faultString="Send failed" faultCode="Client.Error.MessageSend" faultDetail="Unable to load WSDL. If currently online, please verify the URI and/or format of the WSDL (null)"]
            at mx.rpc.soap::WSDLParser/::dispatchFault()
            at mx.rpc.soap::WSDLParser/ http://www.adobe.com/2006/flex/mx/internal::httpFaultHandler()
            at mx.rpc::AbstractInvoker/ http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent()
            at mx.rpc::AbstractInvoker/ http://www.adobe.com/2006/flex/mx/internal::faultHandler()
            at mx.rpc::Responder/fault()
            at mx.rpc::AsyncRequest/fault()
            at mx.messaging::ChannelSet/::faultPendingSends()
            at mx.messaging::ChannelSet/channelFaultHandler()
            at mx.messaging::Channel/mx.messaging:Channel::connectFailed()
            at mx.messaging.channels::PollingChannel/mx.messaging.channels:PollingChannel::connectFailed ()
            at mx.messaging.channels::AMFChannel/mx.messaging.channels:AMFChannel::statusHandler()
            if I visit it using Forefox I get this error .
            Really need this fixed, any help would be great.
