1 Reply Latest reply on Sep 19, 2006 11:53 AM by jasowill
    "send fail" error with remote object
    SallyZhao
      I am developing a web application with FDS remote object. When I develop and test under window with tomcat on localhost, it works fine. However, when I export it as war file and deploy on my linux server, it comes as the following error:
      [RPC Fault faultString="Send failed" faultCode="Client.Error.MessageSend" faultDetail="Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Status 404"]
      at mx.rpc::AbstractInvoker/ http://www.adobe.com/2006/flex/mx/internal::faultHandler()
      at mx.rpc::Responder/fault()
      at mx.rpc::AsyncRequest/fault()
      at mx.messaging::ChannelSet/::faultPendingSends()
      at mx.messaging::ChannelSet/channelFaultHandler()
      at flash.events::EventDispatcher/flash.events:EventDispatcher::dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at mx.messaging::Channel/mx.messaging:Channel::connectFailed()
      at mx.messaging.channels::PollingChannel/mx.messaging.channels:PollingChannel::connectFailed ()
      at mx.messaging.channels::AMFChannel/mx.messaging.channels:AMFChannel::statusHandler()
      It seems something wrong with the FDS configuration, but I couldn't figure out. Can someone help please. Thanks in advance.
        • 1. Re: "send fail" error with remote object
          jasowill
          Check the server log first and see what errors are being reported there during start up of Tomcat. Sounds like the channel configurations haven't been setup properly for the Linux box. You should be able to deploy the same configuration to multiple web apps as long as you specify tokens within the urls for a channel endpoint, i.e. use "{server.name}" and "{server.port}"
