4 Replies Latest reply on Sep 18, 2006 7:31 AM by Newsgroup_User
    HTTPService and HTTPS problem
    Level 7
      I've made an application with many HTTPService request, it runs
      perfectly when urls are HTTP://....
      i've replaced all HTTP requests to HTTPS request and uploaded to an
      HTTPS server then i get the following error on fault event:
      ...Error #2032: Sequence Error...
      faultString="HTTP Request Error"
      * The application uses spanish characters so it has '<?xml version="1.0"
      encoding="iso-8859-1"?>' at the begining of the main mxml file.
      * The crossdomain file contains:
      <?xml version="1.0"?>
      <!DOCTYPE cross-domain-policy SYSTEM
      " http://www.macromedia.com/xml/dtds/cross-domain-policy.dtd">
      <cross-domain-policy>
      <allow-access-from domain="*" />
      </cross-domain-policy>
      * The routine who make the request:
      hs=new HTTPService(null);
      hs.resultFormat='object';
      var t:Array=PATH_PROFESION.split('?');
      if(t[1]!=undefined){
      hs.url=t[0]+'?'+encodeURIComponent(t[1]);
      }else{
      hs.url=PATH_PROFESION;
      hs.destination="DefaultHTTPS";
      hs.method='GET';
      hs.useProxy=false;
      hs.addEventListener("result",getResult_Profesion);
      hs.addEventListener("fault",getFault_Profesion);
      hs.send();
      * The final url is a PHP script with GET parameters like:
      https://xxxxxxxxxx/xxxxx/php_script.php?E:snddata.php&d=profe
      the call to the php script is ok, i'm saving some text to a log file on
      the server so i know the request is comming ok.
      Can you give me a light about it?
      Thanks in advance
        • 1. Re: HTTPService and HTTPS problem
          Level 7
          I've detected it's an Internet Explorer issue, whe i test it on Firefox
          it works perfectly.
          > ....Error #2032: Sequence Error...
          > }else{
          > hs.method='GET';
          > hs.useProxy=false;
          > hs.send();
          > Thanks in advance
          • 2. Re: HTTPService and HTTPS problem
            Level 7
            Solved!!
            Just add headers:
            var headers:Array = new Array("Accept-Encoding", "deflate");
            hs.headers=headers;
            hs.send();
            >> }else{
            >> hs.method='GET';
            >> hs.useProxy=false;
            >> hs.send();
            > it works perfectly.
            >> version="1.0" encoding="iso-8859-1"?>' at the begining of the main
            >> mxml file.
            >> }else{
            >> hs.method='GET';
            >> hs.useProxy=false;
            >> hs.send();
            >> on the server so i know the request is comming ok.
            >> Thanks in advance
            • 3. Re: HTTPService and HTTPS problem
              Level 7
              Sorry, not solved, ignore last post.
              ddanone escribió:
              > Solved!!
              > Just add headers:
              > hs.headers=headers;
              > hs.send();
              > >> }else{
              > >> hs.method='GET';
              > >> hs.useProxy=false;
              > >> hs.send();
              >> Firefox it works perfectly.
              >>> mxml file.
              >>> }else{
              >>> hs.method='GET';
              >>> hs.useProxy=false;
              >>> hs.send();
              >>> Thanks in advance
              • 4. Re: HTTPService and HTTPS problem
                Level 7
                Finally works!! :) It's not a Flex/Flash problem or HTTPS Certificate,
                simply add the following headers to the php script:
                <?php
                header('Pragma: private');
                header('Cache-control: private, must-revalidate');
                > it works perfectly.
                >> mxml file.
                >> }else{
                >> hs.method='GET';
                >> hs.useProxy=false;
                >> hs.send();
                >> Thanks in advance
