7 Replies Latest reply on Oct 23, 2006 1:03 PM by Pitchsole
    Count Down Time Zone?
    Pitchsole
      Hey all, i have come to this fourm a few times and every time i posted help i got it and i got the right help to. So here i am back again. Now here my problem. i made this count down for a certain event. (yes i got help from someone) and it works fine i made all the images it works great,,,so i though then i thought id experament. So i changed my computers time zone and guess what. The Time changed on the count down. Can i make my count down'er', count down from a specific time zone so it will count down and be the same for everyone? so no matter what time zone you have it will ONLY be for a certain type of time zone? Heres my Count down so far;
      http://snro.ifastnet.com/wipe.html
      And heres the script i have for my count down. Can someone give me a better code, so it will keep my counter the exact same just make it count down from only 1 specific Time zone? (AS below)
      quote:
      stop();
      currentDate = new Date();
      thisYear = currentDate.getFullYear();
      // Date( year, month-1, date [, hour [, minute [, second [, millisecond]]]])
      eventDate = new Date(thisYear, 9, 28, 12);
      eventMillisecs = eventDate.getTime();
      counter.onEnterFrame = function(){
      currentMillisecs = currentDate.getTime();
      this.msecs = eventMillisecs - currentMillisecs;
      if (this.msecs <= 0){
      play();
      return;
      this.secs = Math.floor(this.msecs/1000);
      this.mins = Math.floor(this.secs/60);
      this.hours = Math.floor(this.mins/60);
      this.days = Math.floor(this.hours/24);
      this.msecs = string(this.msecs % 1000);
      this.secs = string(this.secs % 60);
      this.mins = string(this.mins % 60);
      this.hours = string(this.hours % 24);
      this.days = string(this.days);
      while (this.msecs.length < 3) this.msecs = "0" + this.msecs;
      if (this.secs.length < 2) this.secs = "0" + this.secs;
      if (this.mins.length < 2) this.mins = "0" + this.mins;
      if (this.hours.length < 2) this.hours = "0" + this.hours;
      while (this.days.length < 3) this.days = "0" + this.days;
      for(movie in this){
      if (this[movie]._parent == this) this[movie].evaluateFrameFrom(this);
      MovieClip.prototype.evaluateFrameFrom = function(variableClip){
      var nameArray = this._name.split("_");
      var numberSet = variableClip[nameArray[0]];
      var character = number(nameArray[1]);
      var frame = 1 + number(numberSet.charAt(character));
      if (this._currentframe != frame) this.gotoAndStop(frame);
      Thanks!
      Edit** If you can the time zone i need it clocked to is (GMT-06:00) Central Time (US & Canada)
        • 1. Re: Count Down Time Zone?
          Level 7
          "Pitchsole" <webforumsuser@macromedia.com> wrote in message
          news:ehgito$dkt$1@forums.macromedia.com...
          > help i
          > though
          > guess
          > count
          > certain
          > better
          > from
          quote:
          stop();
          > millisecond]]]])
          > play();
          > return;
          > for(movie in this){
          > Thanks!
          To let you be the one to further experiment I will point you in the right
          direction.
          http://www.adobe.com/livedocs/flashlite/2/main/wwhelp/wwhimpl/common/html/wwhelp.htm?conte xt=LiveDocs_Parts&file=00000468.html
          Use GMT as your main reference for everyone, then offeset that time to your
          timezone.
          • 2. Re: Count Down Time Zone?
            Pitchsole Level 1
            I am confused, i am not good when it comes to AS, as i said some one helped me. Could you tell me wat to do? or wat to put in? or give me a updated script?
            Thank you
            • 3. Re: Count Down Time Zone?
              Level 7
              news:ehgle0$g9i$1@forums.macromedia.com...
              >script?
              > Thank you
              Alrighty then....
              My code uses a text box instead of your movie clips... but you should get
              the idea.
              Just stick all of this code in an empty frame of a new movie.
              var hoursDifference:Number = 10;
              stop();
              millisecond]]]])
              var counter:TextField = this.createTextField("timeRemaining_txt", 1, 50,
              50, 200, 20);
              counter.text = "TEST";
              var now = new Date();
              var diffFromGMT = now.getTimezoneOffset();
              trace("Diff: " + diffFromGMT);
              var myTimezoneOffset:Number = hoursDifference * 60;
              trace(myTimezoneOffset);
              this.onEnterFrame = function(){
              trace("inside diff = " + (diffFromGMT - myTimezoneOffset));
              currentMillisecs -= (diffFromGMT - myTimezoneOffset) * 60000;
              play();
              return;
              counter.text = this.days + "D " + this.hours + "H " +
              this.mins + "M " + this.secs + "S " + this.msecs + "ms";
              // for(movie in this){
              //if (this[movie]._parent == this) this[movie].evaluateFrameFrom(this);
              • 4. Re: Count Down Time Zone?
                Level 7
                I meant to include a comment for the first line
                // express your number of hours different from GMT.
                // Although you need to use the opposite sign of the difference
                // so, for the example above it would be for Hawaii.
                • 5. Re: Count Down Time Zone?
                  Pitchsole Level 1
                  Well umm..i kinda get it but i do not know wha to replace or wat to take away or wat to add. Couldnt i just add var hoursDifference:Number = 10; and the beggining of my script? or would i have to change the entire thing?
                  • 6. Re: Count Down Time Zone?
                    Level 7
                    Well, I was hoping you could take my example and look at it to figure it
                    out... but here you go:
                    ** Just add the lines with the + signs. Then change to hoursDifference to
                    your negative timezone offset. So, 10 is for Hawaii.
                    + var hoursDifference:Number = 10;
                    + var now = new Date();
                    + var diffFromGMT = now.getTimezoneOffset();
                    + var myTimezoneOffset:Number = hoursDifference * 60;
                    millisecond]]]])
                    + currentMillisecs -= (diffFromGMT - myTimezoneOffset) * 60000;
                    play();
                    return;
                    for(movie in this){
                    • 7. Re: Count Down Time Zone?
                      Pitchsole Level 1
                      Thank You!
