4 Replies Latest reply on Oct 22, 2006 4:29 AM by andyulrika_is_back
    Help with code for unresolved hyperlink issue
    andyulrika_is_back
      Hello
      Can someone please help with this one - I need some code to do the following:
      To be able to click on a hyperlink within a text sprite and jump to another marker location within the score. At the new position some text at the foot of the page displays - 'return to (name of previous marker)'. This should only display if a hyperlink was used.
      Help much appreciated.
      Andy
        • 1. Re: Help with code for unresolved hyperlink issue
          duckets Level 1
          The simplest way to do this would be to use a global variable to store the frame label when a hyperlink is clicked. eg:
          global backFrameLabel
          on mouseUp me
          backFrameLabel = the frameLabel
          end
          Then, on frames which require the back button, you'll need to check whether the 'backFrameLabel' global contains a label name. If so, you make your button visible, set its text, and make the mouseup function work. if not, the button should be invisible (moved off stage). Finally, when the back button is used, the 'backFrameLabel' should be cleared.
          Something like this:
          on beginsprite me
          if stringP(backFrameNumber) then
          sprite(me.member.text) = "Return to "&backFrameLabel
          else
          sprite(me.spritenum).loch = -9999
          end if
          end
          on mouseup me
          if stringp(backFrameLabel) then
          goFrameLabel = backFrameLabel
          backFrameLabel = void
          go to frame(goFrameLabel)
          end if
          end
          hope this helps!
          (note - written in reply box, untested lingo!)
          - Ben
          • 2. Re: Help with code for unresolved hyperlink issue
            andyulrika_is_back Level 1
            Hi Ben
            Thanks again. But I'm getting a script error when attaching the second part of your coding below
            and don't know how to fix.
            Which displays the following:
            Script Error: Expected =
            sprite(me.member.text)=? "Return to &backFrameLabel
            Also, I changed the code in the second part of your coding which referenced - if stringP(backFrameNumber) to if stringP(backFrameLabel)
            Can you help?
            Thanks in advance
            Andy
            • 3. Re: Help with code for unresolved hyperlink issue
              Level 7
              This line should read:
              sprite(me.spriteNum).member.text = "Return to "&backFrameLabel
              Dave -
              Head Developer
              www.blurredistinction.com
              Adobe Community Expert
              http://www.adobe.com/communities/experts/
              • 4. Re: Help with code for unresolved hyperlink issue
                Hi Dave
                Thanks for that piece of code - This fixed it. Although, I still can't get the code to do exactly what I want...
                So far, I can get the text on the target marker to display "return to (previous marker name)" but clicking on this doesn't actively take me back to the previous marker and the offstage code totally makes the sprite dissapear.
                Here is what I have done so far -
                Created a global script within the cast
                on mouseUp me
                end
                Attached the following code to my Text sprite on the stage:
                on mouseUp me
                end
                on hyperLinkClicked me, data,
                go data
                end
                On the target frame I created a field text sprite at the foot of the page and attached the following:
                on beginsprite me
                if stringP(backFrameLabel) then
                else
                end if
                end
                on mouseup me
                end if
                end
                The previous frame label is displayed but I can't get it to jump back to the frame label when clicking on it.
                Any ideas?
                regards
                Andy
