1 Reply Latest reply on Sep 18, 2006 8:47 AM by Newsgroup_User
    unzip zipfile with nonenglish filenames
    Level 7
      hi, all
      i tried to use apache foundation alternative (supports encoding
      parameter to resolve filenames encoding) to standard unzipping classes
      located in JVM 1.4.x. classes are located in package
      org.apache.tools.zip.* in ant.jar
      everything works fine in tomcat, but in JRun/CF7 following message is
      displayed ...
      as you can guess cf also uses ant.jar, and that is probably the problem.
      thanks for advice,
      jan
      tried to access field org.apache.tools.zip.ZipOutputStream.EOCD_SIG from
      class org.apache.tools.zip.ZipFile
      java.lang.IllegalAccessError: tried to access field
      org.apache.tools.zip.ZipOutputStream.EOCD_SIG from class
      at
      org.apache.tools.zip.ZipFile.positionAtCentralDirectory(ZipFile.java:348)
      at
      org.apache.tools.zip.ZipFile.populateFromCentralDirectory(ZipFile.java:243)
      at org.apache.tools.zip.ZipFile.(ZipFile.java:142)
      at cz.sitewell.zip.Zipping.decompress(Zipping.java:66)
      at cz.sitewell.zip.Zipping.decompress(Zipping.java:54)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at
      sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
      at
      sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:324)
      at coldfusion.runtime.StructBean.invoke(StructBean.java:388)
      at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:1655)
      at
      cftestik2ecfm365833867.runPage(C:\JRun4\servers\cfusion\cfusion-ear\cfusion-war\testik.cf m:18)
      at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:152)
      at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:343)
      at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
      at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:210)
      at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)
      at coldfusion.filter.LicenseFilter.invoke(LicenseFilter.java:27)
      at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:50)
      at
      coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)
      at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
      at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
      at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
      at coldfusion.CfmServlet.service(CfmServlet.java:105)
      at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:78)
      at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
      at
      jrunx.util.DynamicClassLoaderFilter.doFilter(DynamicClassLoaderFilter.java:48)
      at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
      at jrun.servlet.FilterChain.service(FilterChain.java:101)
      at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
      at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
      at
      jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:259)
      at
      jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:541)
      at jrun.servlet.http.WebService.invokeRunnable(WebService.java:172)
      at
      jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
      at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
        • 1. Re: unzip zipfile with nonenglish filenames
          Level 7
          hello,
          i found the problem but not solution yet ...
          in jrun.jar is located some ancient (4years old) version of ant
          without ZipFile class. That class is loaded from newer version of ant.jar.
          protected fields probably work only on same jars, not packages.
          because of this IllegalAccessError is throwed.
          is there some elegant solution to load newer version of ant? of course
          i see some workarounds such as modification of jrun.jar or package
          renaming to solve this ...
          jan
          Jan Gregor wrote:
          > hi, all
          > displayed ...
          > thanks for advice,
          > jan
          > at
          > at
          > at
          > at
          > at
          > at
          > at
          > at
          > at
          > at
          > at
          > at
