9 Replies Latest reply on Aug 26, 2009 2:23 PM by smohadjer
    Streaming Video Progress Bar
    quovadimus02 Level 1
      I need to create a progress bar for my streaming video to let the user know how much of the video has already been downloaded/streamed. Making a progress bar for a progressive download is easy, just check the bytesLoaded vs the bytesTotal. But apparently with a streaming video those do not work. What exactly do I need to check in order to create a progress bar for a streaming video. Here is my sample code that doesn't work for the progress bar.
        • 1. Re: Streaming Video Progress Bar
          Level 7
          Hi!
          You might want to check out the video basics tutorials (8 of them in total)
          at
          http://www.gotoandlearn.com/
          /Jensen/
          "quovadimus02" <webforumsuser@macromedia.com> wrote in message
          news:ehalfi$deh$1@forums.macromedia.com...
          >how
          > bar
          > streaming
          > var startingCheckX:Number = loader_mc.seek_mc._x;
          > // updates loader bar as well as progress indicator
          > function checkBytesLoaded() {
          > amountLoaded = ns.bytesLoaded / ns.bytesTotal;
          > loader_mc.bar_mc._width = amountLoaded * 280;
          > loader_mc.seek_mc._x = startingCheckX + (ns.time / duration * 280);
          > var minsElapsed:Number = Math.floor(ns.time / 60); // find number of
          > minutes
          > var secsElapsed:Number = Math.floor(ns.time % 60); // find remaining
          > seconds
          > var minsTotal:Number = Math.floor(duration / 60); // find total number of
          > minutes
          > var secsTotal:Number = Math.floor(duration % 60); // find total number of
          > seconds
          > // add leading zero for single digit values
          > minsElapsed = (minsElapsed < 10) ? "0" + minsElapsed : minsElapsed;
          > secsElapsed = (secsElapsed < 10) ? "0" + secsElapsed : secsElapsed;
          > minsTotal = (minsTotal < 10) ? "0" + minsTotal : minsTotal;
          > secsTotal = (secsTotal < 10) ? "0" + secsTotal : secsTotal;
          > loader_mc.counter_txt.text = minsElapsed + ":" + secsElapsed + " / " +
          > minsTotal + ":" + secsTotal;
          > loadedInterval = setInterval(checkBytesLoaded,100);
          • 2. Re: Streaming Video Progress Bar
            Thanks for the link but all those tutes deal with the basics of dealing with progressive videos. I'm trying to create a loading bar for a streaming video which is a bit different apparently.
            • 3. Re: Streaming Video Progress Bar
              TimSymons Level 1
              The FLVPlayback componet has a bufferingBar piece that does what you are asking. The user can see the video window but you can use the following FLVPlayback properties to control the look and feel of the buffering bar.
              FLVPlayback.buffering
              FLVPlayback.bufferingBar
              FLVPlayback.bufferingBarHidesAndDisablesOthers
              FLVPlayback.bufferTime
              Tim
              • 4. Re: Streaming Video Progress Bar
                Unfortunately using the playback component is not an option in this case. Any other ideas are certainly welcome.
                • 5. Re: Streaming Video Progress Bar
                  TimSymons Level 1
                  How are you playing the video? Is it a custom component or code?
                  Tim
                  • 7. Re: Streaming Video Progress Bar
                    TimSymons Level 1
                    I would assume that you are using NetStream then. You should be looking at
                    bufferTime
                    bufferLength
                    of the NetStream class.
                    Tim
                    • 8. Re: Streaming Video Progress Bar
                      Sorry for the lull in response, I was away from a computer all weekend. Anyways, I tried checking the bufferTime vs the bufferLength in my loader script but with no luck. My progress bar, which should only be 280px, starts out ridiculously long, much longer than the stage and xScales down until it gets to about the half way point of the loader then it starts xScaling in the correct direction. Once it fills the loader it shrinks back down to about the half way point and fills again and the process repeats. My loader code is attached below. You can also see my sample file here. Thanks for all your help thus far.
                      • 9. Re: Streaming Video Progress Bar
                        smohadjer
                        I have the same problem. How does one show the download progress for a streamed video suing Flash Media Server 3 & ActionScript 3? I know that  ns.bytesLoaded/ns.bytesTotal only works with progressive download so it's of no use and ns.bufferLength/ns.bufferTime keeps returning a fluctuating value which is certainly not indicating download progress.
                        I'm starting to think that there is no way to display download progress of a streamed video at all. Can that be the case?
