18 Replies Latest reply on Oct 31, 2006 6:32 PM by Detonate 2004
    Manipulate xml data
    Detonate 2004
      From a XML file, I can retrieve the content and display in one single column. This part works perfectly!
      But when it comes to seperate my xml data in 2 columns... no luck.
      Can anyone guide me and split my items in a new row when 10 items are achieved?
        • 1. Re: Manipulate xml data
          injpix Level 3
          The code below uses two unique conditionals to pick left or right depending if the number is an even or odd. So it will make 2 vertical columns when completed. It will construct rows first versus columns.
          Copy this code into a new FLA and watch the trace statements. Do you see how this can help you? If not just ask. Also these two links are for reference for those 2 conditional.
          http://www.quip.net/blog/2006/flash/actionscript-20/lesser-known-operators-modulo
          http://www.quip.net/blog/2006/flash/actionscript-20/lesser-known-operators-conditional
          • 2. Re: Manipulate xml data
            Detonate 2004 Level 1
            myIP, thanks a bunch for this pointer...
            Never even thought of attacking my issue with modulus
            or a similar approach.
            What approach should I use in case I need a 3rd one?
            Below is my current state and tryout. It worked ok but for one thing.
            It does split my items in 2 columns. However creates an empty cell
            on either "right" or "left" sides. Ex:
            xxxxx ---------
            --------- xxxxxx
            xxxxx ---------
            --------- xxxxxx
            xxxxx ---------
            --------- xxxxxx
            and so on.
            I wasn't able to isolate var nextRow:Number = 10;
            Any help would be appreciated =)
            • 3. Re: Manipulate xml data
              injpix Level 3
              Copy the code below to have 3 columns.
              The “nextRow” acts like a ‘return’ button, just like your keybroad for your computer. It will increase the value of _y (if you assign the value to it) each time it reaches the end of the row.
              • 4. Re: Manipulate xml data
                Suggested code worked almost like a charm. It did break my xml content in 3 colums.
                However, I was never able break into correct horizontal rows.
                I understand that _y and variable "i" is invoked each time an decals diagonaly the items...
                Any suggs myIp? I would simply like it to break in perfect rows. I'm out of ideas.
                (tried implementing with “nextRow” but simply applies the items over another without affecting my _y axis)
                Thanks for helping out, it means a lot!
                • 5. Re: Manipulate xml data
                  injpix Level 3
                  Hmmm…I don’t see how your ‘i’ is getting incremented in your last post. However, paste the code below into a new FLA. What you needed to do in my last code was to assign nextRow to your ‘_y’ property.
                  • 6. Re: Manipulate xml data
                    myIP, pm'd you
                    • 7. Re: Manipulate xml data
                      Nixy Level 1
                      Go to this address: www.november7.ca/setItemOnStage.zip
                      You'll find an easy way to set item on stage. Just have to use your XML with.
                      Variable on top must be your. Number of items will depends on the number of XML nodes you have. For now I just put a number to test it.
                      Hopa that can help
                      • 8. Re: Manipulate xml data
                        Nixy, thanks for helping out with this very comprehensible example.
                        Again, it's nice to see another different approach for my issue.
                        Only wish I could integrate it correctly =L
                        I've tried implementing this for a couple of days within my app. and couldn't get it to work.
                        (All my items appeared over each other or it didn't retreive my xml correctly etc. )
                        Here is the isolated section of my script where I'm trying to get this working:
                        • 9. Re: Manipulate xml data
                          Approaching MyIP's suggestion, here is my latest dev.
                          ------------> Latest dev link
                          Pretty close but not quite there.
                          Anyone care to check and help out?
                          • 10. Re: Manipulate xml data
                            Please take a look at my link above this message,
                            all my source is there. You will be able to alter and view
                            the code easily and without confusion.
                            • 11. Re: Manipulate xml data
                              Nixy Level 1
                              Sorry for the delay
                              Here is a link to download the new file : http://www.november7.ca/xml_StageHelpfolder.zip
                              The function used to display the submenu is all new. You'll see this part at the bottom of your document. I have change some little thing in the first part of your code, but nothing important. Just to undestand the way you've code that, only. I have separate the function "makeMenu" in 2 functions "makeMenu" and "makeSubMenu". It's a good practice to keep function simple.
                              If you have any question on how it works, let me know.
                              Also, just before the new function, at the bottom, there is many variables. You can use them to manage you submenu display. Distance between, number per column, etc..
                              Hopa that can help!
                              • 12. Re: Manipulate xml data
                                thanks Nixy,
                                been figuring out how you implemented the code. Where it grabs and distributes etc. nice logic behind this... very clever function too!
                                somehow, once I click on the items no images can retreive from the xml.
                                I tried altering, adding from the old piece and nothing. no wizardry
                                think it might have to do with these older lines(.push & with):
                                levelTwoItems.push(levelTwoEmpty.attachMovie("levelTwoItem", "item" + i, i));
                                with (levelTwoEmpty["item" + i])
                                did put up a file with clean UI.
                                this is definitely the last blocking step
                                • 13. Re: Manipulate xml data
                                  Nixy Level 1
                                  I just modify the code in the fla
                                  You can download it there : New Doc here
                                  I've put a new function at the bottom of your code that will allow you to add or modify submenu events. You'll find an example of the onRelease event. Actually it just trace the IMG tag. So you can change it to load the image or do whatever you want with.
                                  Hope that can help.
                                  • 14. Re: Manipulate xml data
                                    nixy, I tried implementing the latest function in place but can't seem to assign the correct item values.
                                    How can I combine you latest piece of code with my last part? Been having a hard day... not giving up tho ;)
                                    • 15. Re: Manipulate xml data
                                      Nixy Level 1
                                      Hi Detonate
                                      Here it is: GET IT HERE
                                      I have modified some part of each functions at the bottom. So change tehm all. Just those at the bottom. I also change the "makeSubMenu" function at the top of your code. In this function the parameters is now "node" and no more "node.childNodes". To long to explain, but it works perfectly now. When I change the code before I didn't thought that you wiil need the menu type. That is the reson why I need to keep the all the node not just the node.childNodes. Well at the bottom, here is what I did:
                                      1- In the "attachSubMenuItem" the is a button id for each clip. Use to now wich subment have been clicked
                                      2- I still use the "setSubmenuEvents" function even if the is only one event in. It's a good way to work in case of you'd like to add other events.
                                      3- I had change a bit of your code in the "levelTwoEmpty["item"+i].onRelease" now named as "clickEventSub". Not just an event, but a function. Code inside has been modify to works with the new code. Also I use the switch case instead of the if else if else etc. In this case It<s a good way to works. Also actually the code for the id web or img is the same, so instead of having 2 different if, I put tehm in the same, actually the default value in the switch case.
                                      Hope that can help.
                                      • 16. Re: Manipulate xml data
                                        nixy,
                                        this is working perfectly and without a glitch. Your coding skills are very impressive!
                                        This post was a learning journey for me and I'm hoping to give back in return someday. With all respect for your help, time and contribution.
                                        Merci énormément =)
                                        • 17. Manipulate xml data
                                          nixy, everything ok but one bug I can't figure out. no text is pulled from the xml in the "last menu item". I added to your switch statement below for debuging. Assigning each xml item type correctly. If you place the xml below and retrieve in the flash piece with "viewArea" on stage, you'll notice that our xml text item can be shown without any trouble... any idea where this might be going wrong?
                                          <menu name="Test5" type="text">
                                          <item name="TestText1">
                                          <![CDATA[Text text text]]>
                                          </item>
                                          <item name="TestText2">
                                          </item>
                                          </menu>
                                          • 18. Re: Manipulate xml data
                                            viewArea.textonly.textField.text = menuItems.childNodes[theMc.id].firstChild.nodeValue;
                                            works =)
                                            Again, thanks Nixy for your help and patience
