3 Replies Latest reply on Sep 27, 2006 8:24 PM by ageofem
    Vertical grad fill fix..when!????
    TechyBloke Level 1
      I'm sure this problem has been mentioned before, but I was wondering when Adobe were going to fix the problem that sometimes (lots of times) happens that will not allow you to position the grad direction tool in a vertical straight position.
      I've been encountering this problem for years and it can't be THAT difficult for the masterminds at Adobe to sort out.....
      When are we likely to get a fix? I don't expect such major problems as this with software that costs hundreds of pounds (UK)
        • 1. Re: Vertical grad fill fix..when!????
          Level 7
          I'm inclined to agree. I get so used to using the workaround that I tend to
          forget about it.
          But the fact by using the Gradient tool from the Colors section of the Tools
          menu works perfectly in my experience, would suggest this isn't a major
          problem to fix?
          Peter
          ________________________
          "TechyBloke" <webforumsuser@macromedia.com> wrote in message
          news:ef9a1v$ovv$1@forums.macromedia.com...
          | Hi,
          that
          straight
          | position.
          difficult
          this
          • 2. Re: Vertical grad fill fix..when!????
            TechyBloke Level 1
            Thanks, I didn't know about the grad tool from the colors menu. It does work, many thanks.
            quote:
            forget about it.
            problem to fix?
            Peter
            | Hi,
            that
            straight
            | position.
            difficult
            this
