11 Replies Latest reply on Sep 6, 2007 12:33 PM by tomj
    Problem in Consuming a Web Service running on Remedy
    SandyVohra
      Hi All – We have a web service running on ARSystem ( Remedy) and all we would like to do is –
      -Invoke this web service from our Coldfusion page
      -Send some parameters in a method call for ‘Remedy WS’
      -This Webservice returns a simple String object.
      The WSDL looks like this..
      <?xml version="1.0" encoding="UTF-8" ?>
      - <wsdl:definitions targetNamespace="urn:CHG_Change_WebService_OpCreate_DisplayOnly_v2" xmlns=" http://schemas.xmlsoap.org/wsdl/" xmlns:s="urn:CHG_Change_WebService_OpCreate_DisplayOnly_v2" xmlns:soap=" http://schemas.xmlsoap.org/wsdl/soap/" xmlns:soapenc=" http://schemas.xmlsoap.org/soap/encoding/" xmlns:wsdl=" http://schemas.xmlsoap.org/wsdl/" xmlns:xsd=" http://www.w3.org/2001/XMLSchema">
      - <wsdl:types>
      - <xsd:schema elementFormDefault="qualified" targetNamespace="urn:CHG_Change_WebService_OpCreate_DisplayOnly_v2">
      <xsd:element name="OpCreate" type="s:CreateInputMap" />
      - <xsd:complexType name="CreateInputMap">
      - <xsd:sequence>
      <xsd:element name="Description" type="xsd:string" />
      <xsd:element name="Requester_Login_Name" type="xsd:string" />
      <xsd:element name="Requester_Name" type="xsd:string" />
      </xsd:sequence>
      </xsd:complexType>
      <xsd:element name="OpCreateResponse" type="s:CreateOutputMap" />
      - <xsd:complexType name="CreateOutputMap">
      <xsd:sequence />
      </xsd:complexType>
      <xsd:element name="AuthenticationInfo" type="s:AuthenticationInfo" />
      - <xsd:complexType name="AuthenticationInfo">
      - <xsd:sequence>
      <xsd:element name="userName" type="xsd:string" />
      <xsd:element name="password" type="xsd:string" />
      <xsd:element minOccurs="0" name="authentication" type="xsd:string" />
      <xsd:element minOccurs="0" name="locale" type="xsd:string" />
      <xsd:element minOccurs="0" name="timeZone" type="xsd:string" />
      </xsd:sequence>
      </xsd:complexType>
      </xsd:schema>
      </wsdl:types>
      - <wsdl:message name="OpCreateSoapOut">
      <wsdl:part element="s:OpCreateResponse" name="parameters" />
      </wsdl:message>
      - <wsdl:message name="ARAuthenticate">
      <wsdl:part element="s:AuthenticationInfo" name="parameters" />
      </wsdl:message>
      - <wsdl:message name="OpCreateSoapIn">
      <wsdl:part element="s:OpCreate" name="parameters" />
      </wsdl:message>
      - <wsdl:portType name="CHG_Change_WebService_OpCreate_DisplayOnly_v2PortType">
      - <wsdl:operation name="OpCreate">
      <wsdl:input message="s:OpCreateSoapIn" />
      <wsdl:output message="s:OpCreateSoapOut" />
      </wsdl:operation>
      </wsdl:portType>
      - <wsdl:binding name="CHG_Change_WebService_OpCreate_DisplayOnly_v2SoapBinding" type="s:CHG_Change_WebService_OpCreate_DisplayOnly_v2PortType">
      <soap:binding style="document" transport=" http://schemas.xmlsoap.org/soap/http" />
      <soap:operation soapAction="urn:CHG_Change_WebService_OpCreate_DisplayOnly_v2/OpCreate" style="document" />
      - <wsdl:input>
      <soap:header message="s:ARAuthenticate" part="parameters" use="literal" />
      <soap:body use="literal" />
      </wsdl:input>
      - <wsdl:output>
      </wsdl:output>
      </wsdl:operation>
      </wsdl:binding>
      - <wsdl:service name="CHG_Change_WebService_OpCreate_DisplayOnly_v2Service">
      - <wsdl:port binding="s:CHG_Change_WebService_OpCreate_DisplayOnly_v2SoapBinding" name="CHG_Change_WebService_OpCreate_DisplayOnly_v2Soap">
      <soap:address location=" http://<ServerName>/arsys/services/ARService?server=<ServerName>&webService=CHG_Change_Web Service_OpCreate_DisplayOnly_v2" />
      </wsdl:port>
      </wsdl:service>
      </wsdl:definitions>
      My CF invocation is as given below..
      <cfscript>
      Ws=CreateObject("webservice"," http://<servername>/arsys/WSDL/public/<servername>/CHG_Change_WebService_OpCreate_DisplayO nly_v2");
      result= ws.opCreate("test1","TEST2","test3");
      </cfscript>
      <cfoutput>|#result#|</cfoutput>
      AND I am getting this error below..
      Could not generate stub objects for web service invocation.
      Name: http://<servername>/arsys/WSDL/public/<servername>/CHG_Change_WebService_OpCreate_DisplayO nly_v2. WSDL: http:// <servername>/arsys/WSDL/public/<servername>/CHG_Change_WebService_OpCreate_DisplayOnly_v2 . java.lang.NullPointerException It is recommended that you use a web browser to retrieve and examine the requested WSDL document for correctness. If the requested WSDL document can't be retrieved or it is dynamically generated, it is likely that the target web service has programming errors.
      Java Stack trace:
      at org.apache.axis.wsdl.toJava.Utils.getNewQNameWithLastLocalPart(Utils.java:933)
      at org.apache.axis.wsdl.toJava.JavaStubWriter.writeOperationMap(JavaStubWriter.java:610)
      at org.apache.axis.wsdl.toJava.JavaStubWriter.writeFileBody(JavaStubWriter.java:169)
      at org.apache.axis.wsdl.toJava.JavaWriter.generate(JavaWriter.java:130)
      at org.apache.axis.wsdl.toJava.JavaBindingWriter.generate(JavaBindingWriter.java:147)
      at org.apache.axis.wsdl.toJava.JavaGeneratorFactory$Writers.generate(JavaGeneratorFactory.ja va:423)
      at org.apache.axis.wsdl.gen.Parser.generate(Parser.java:471)
      at org.apache.axis.wsdl.gen.Parser.run(Parser.java:395)
      at org.apache.axis.wsdl.toJava.Emitter.run(Emitter.java:611)
      at coldfusion.xml.rpc.XmlRpcServiceImpl$1.run(XmlRpcServiceImpl.java:213)
      at java.security.AccessController.doPrivileged(Native Method)
      at coldfusion.xml.rpc.XmlRpcServiceImpl.registerWebService(XmlRpcServiceImpl.java:198)
      at coldfusion.xml.rpc.XmlRpcServiceImpl.getWebService(XmlRpcServiceImpl.java:472)
      at coldfusion.xml.rpc.XmlRpcServiceImpl.getWebServiceProxy(XmlRpcServiceImpl.java:427)
      at coldfusion.xml.rpc.XmlRpcServiceImpl.getWebServiceProxy(XmlRpcServiceImpl.java:409)
      at coldfusion.runtime.CFPage.createObject(CFPage.java:5993)
      at coldfusion.runtime.CFPage.CreateObject(CFPage.java:5848)
      at coldfusion.runtime.CFPage.CreateObject(CFPage.java:5813)
      at cftest1252ecfm1199621501.runPage(D:\Inetpub\wwwroot\Pearsontc\sandytest\test125.cfm:11)
      at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:152)
      at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:343)
      at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
      at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:210)
      at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:51)
      at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)
      at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:50)
      at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)
      at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
      at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
      at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
      at coldfusion.CfmServlet.service(CfmServlet.java:105)
      at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:78)
      at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
      at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
      at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:257)
      at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:527)
      at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:204)
      at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:349)
      at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:457)
      at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:295)
      at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
      Would be sincerely thankful to ALL who could help me in resolving my problem as it’s a deadline for me today and I have some testing left to be done on some other modules as well.
      PLEASE PLEASE HELP!!
      Thanks.
      -S
        • 1. Re: Problem in Consuming a Web Service running on Remedy
          Level 7
          Starting with the basics, can you type the URI to the WSDL file and get
          the WSDL to display in a browser? If so, you copied this URI into your
          createOject code and it fails?
          What OS?
          Is there any security involved in the system generating the WSDL?
          SandyVohra wrote:
          > Hi All ? We have a web service running on ARSystem ( Remedy) and all we would
          > like to do is ?
          • 2. Re: Problem in Consuming a Web Service running on Remedy
            SandyVohra Level 1
            Thanks ian for prompt reply.
            Yes I am getting the wsdl and thats what I pasted in my original request.
            Exactly - The same URI in createObject or CFINVOKE does not work.
            My CF MX 7.0 is on Windows 2k3.
            I have been trying hard to make this work using CFINVOKE or CFHTTP invoking operation name by passing it as a URI but no luck.
            Any help will be highly appreciated..
            Thanks.
            • 3. Re: Problem in Consuming a Web Service running on Remedy
              Level 7
              A first guess would be that this could be a permission issue. The
              default user that the ColdFusion service runs under has very basic
              permissions beyond it's own server. If maybe that the CF user does not
              have permission to access this resource.
              If you can play with the user the the CF service logs on under and set
              it to yourself, then see if this changes anything. If it does, this is
              not a permanant solution. You will want to create a user just for the
              coldfusion service that has just the permissions that it needs and use
              this instead of your personal creditionals.
              > Thanks.
              • 4. Re: Problem in Consuming a Web Service running on Remedy
                SandyVohra Level 1
                Ian, Thanks but service is running on REMEDY system and is written in Java. The new wsdl looks like this..( Please check the complex type input and return parameter). I cannot change the service permissions as its not in our control
                http://oldtas184/arsys/WSDL/ <?xml version="1.0" encoding="UTF-8" ?>
                - <wsdl:types>
                - <xsd:sequence>
                </xsd:sequence>
                </xsd:complexType>
                - <xsd:sequence>
                </xsd:sequence>
                </xsd:complexType>
                - <xsd:sequence>
                </xsd:sequence>
                </xsd:complexType>
                </xsd:schema>
                </wsdl:types>
                </wsdl:message>
                </wsdl:message>
                </wsdl:message>
                </wsdl:operation>
                </wsdl:portType>
                - <wsdl:input>
                </wsdl:input>
                - <wsdl:output>
                </wsdl:output>
                </wsdl:operation>
                </wsdl:binding>
                <soap:address location=" http://oldtas184/arsys/services/ARService?server=OLDTAS184&webService=CHG_Change_WebServic e_OpCreate_DisplayOnly_v2" />
                </wsdl:port>
                </wsdl:service>
                </wsdl:definitions>
                I have modified my code a little to use a struct object and the code looks as below..
                <cfscript> CreateInputMap1 = structNew();
                CreateInputMap1.Description = "test";
                CreateInputMap1.Requester_Login_Name = "xxxxxx";
                CreateInputMap1.Requester_Name = "yyyyyyy";
                ws=CreateObject("webservice"," http://oldtas184/arsys/WSDL/public/OLDTAS184/CHG_Change_WebService_OpCreate_DisplayOnly_v2 ?wsdl");
                result= ws.opCreate(CreateInputMap1);
                </cfscript>
                <cfoutput>#result#</cfoutput>
                But I still receive the same error..
                Error Occurred While Processing Request
                Name: http://oldtas184/arsys/WSDL/public/OLDTAS184/CHG_Change_WebService_OpCreate_DisplayOnly_v2 ?wsdl. WSDL: http://oldtas184/arsys/WSDL/public/OLDTAS184/CHG_Change_WebService_OpCreate_DisplayOnly_v2 ?wsdl. java.lang.NullPointerException It is recommended that you use a web browser to retrieve and examine the requested WSDL document for correctness. If the requested WSDL document can't be retrieved or it is dynamically generated, it is likely that the target web service has programming errors.
                The error occurred in D:\Inetpub\wwwroot\Pearsontc\sandytest\test125.cfm: line 18
                16 : CreateInputMap1.Requester_Name = "Vohra";
                17 :
                18 : ws=CreateObject("webservice"," http://oldtas184/arsys/WSDL/public/OLDTAS184/CHG_Change_WebService_OpCreate_DisplayOnly_v2 ?wsdl");
                19 : // addSOAPRequestHeader(ws, " http://oldtas184/arsys/WSDL/public/OLDTAS184/CHG_Change_WebService_OpCreate_DisplayOnly_v2 /", "Description", "test", false);
                20 : // addSOAPRequestHeader(ws, " http://oldtas184/arsys/WSDL/public/OLDTAS184/CHG_Change_WebService_OpCreate_DisplayOnly_v2 /", "Requester_Login_Name", "John", false);
                Stack Trace (click to expand)
                at cftest1252ecfm1199621501.runPage(D:\Inetpub\wwwroot\Pearsontc\sandytest\test125.cfm:18) at cftest1252ecfm1199621501.runPage(D:\Inetpub\wwwroot\Pearsontc\sandytest\test125.cfm:18)
                The REMEDY logs has this message - "Required element expected in the input XML document":
                • 5. Re: Problem in Consuming a Web Service running on Remedy
                  Level 7
                  Here is an example on how to type parameters and create complex
                  parameters. HTH.
                  <cfparam name="WAVEH" default = false type="boolean">
                  <cfparam name="maxt" default = true type="boolean">
                  <cfparam name="mint" default = true type="boolean">
                  <cfparam name="tempx" default = false type="boolean">
                  <cfparam name="dew" default = false type="boolean">
                  <cfparam name="pop12" default = false type="boolean">
                  <cfparam name="qpf" default = false type="boolean">
                  <cfparam name="snow" default = false type="boolean">
                  <cfparam name="sky" default = false type="boolean">
                  <cfparam name="wspd" default = false type="boolean">
                  <cfparam name="wdir" default = false type="boolean">
                  <cfparam name="wx" default = false type="boolean">
                  <cfparam name="icons" default = false type="boolean">
                  <cfparam name="waveh" default = false type="boolean">
                  <cfparam name="startDate" default="#now()#" type="date">
                  <cfparam name="numDays" default="7" type="numeric">
                  <cfparam name="format" default="24 hourly" type="string">
                  <cfset strWeatherParameters = STRUCTNEW() />
                  <cfset strWeatherParameters.WAVEH = WAVEH />
                  <cfset strWeatherParameters.maxt = maxt />
                  <cfset strWeatherParameters.mint = mint />
                  <cfset strWeatherParameters.temp = tempx />
                  <cfset strWeatherParameters.dew = dew />
                  <cfset strWeatherParameters.pop12 = pop12 />
                  <cfset strWeatherParameters.qpf = qpf />
                  <cfset strWeatherParameters.snow = snow />
                  <cfset strWeatherParameters.sky = sky />
                  <cfset strWeatherParameters.wspd = wspd />
                  <cfset strWeatherParameters.wdir = wdir />
                  <cfset strWeatherParameters.wx = wx />
                  <cfset strWeatherParameters.icons = icons />
                  <cfset strWeatherParameters.waveh = waveh />
                  <cfinvoke webservice =
                  " http://weather.gov/forecasts/xml/DWMLgen/wsdl/ndfdXML.wsdl"
                  method = "NDFDgenByDay"
                  returnvariable = "xmlWeatherData">
                  <cfinvokeargument name="latitude" value="38.697054"/>
                  <cfinvokeargument name="longitude" value="-121.3582"/>
                  <cfinvokeargument name="startDate" value="#startDate#"/>
                  <cfinvokeargument name="numDays" value="#numDays#"/>
                  <cfinvokeargument name="format" value="#format#"/>
                  </cfinvoke>
                  <cfset NDFDgenByDayData = XMLParse(xmlWeatherData) />
                  method = "NDFDgen"
                  <cfinvokeargument name="latitude" value="42.3485"/>
                  <cfinvokeargument name="longitude" value="-71.0733"/>
                  <cfinvokeargument name="product" value="time-series"/>
                  <cfinvokeargument name="startTime" value="#now()#"/>
                  <cfinvokeargument name="endTime" value="#dateAdd('d',7,now())#"/>
                  <cfinvokeargument name="weatherParameters" value="#strWeatherParameters#"/>
                  </cfinvoke>
                  <cfset NDFDgenData = XMLParse(xmlWeatherData) />
                  <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
                  " http://www.w3.org/TR/html4/loose.dtd">
                  <html>
                  <head>
                  <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
                  <title>Untitled Document</title>
                  </head>
                  <body>
                  <cfdump var="#server#">
                  <cfdump var="#NDFDgenByDayData#">
                  <cfdump var="#NDFDgenData#">
                  </body>
                  </html>
                  > parameter).
                  • 6. Re: Problem in Consuming a Web Service running on Remedy
                    SandyVohra Level 1
                    Hey Ian - The code you sent worked perfectly as it is supposed to do and I am creating the structs in a similar fashion in my code as well. But the problem is still with invoking this Java Web Service. Looking at the wsdl which I have pasted again below.. what do you think should be a straight CF Code which should be able to invoke this web service. I have my CFSCRIPT and CFINVOKE code below that as well..Do you see any need of SOAP Headers and stuff..
                    I would owe you one if this is resolved.
                    - <wsdl:types>
                    - <xsd:sequence>
                    </xsd:sequence>
                    </xsd:complexType>
                    - <xsd:sequence>
                    </xsd:sequence>
                    </xsd:complexType>
                    - <xsd:sequence>
                    </xsd:sequence>
                    </xsd:complexType>
                    </xsd:schema>
                    </wsdl:types>
                    </wsdl:message>
                    </wsdl:message>
                    </wsdl:message>
                    </wsdl:operation>
                    </wsdl:portType>
                    - <wsdl:input>
                    </wsdl:input>
                    - <wsdl:output>
                    </wsdl:output>
                    </wsdl:operation>
                    </wsdl:binding>
                    </wsdl:port>
                    </wsdl:service>
                    </wsdl:definitions>
                    <cfinvoke webservice=" http://oldtas184/arsys/WSDL/public/OLDTAS184/CHG_Change_WebService_OpCreate_DisplayOnly_v2 ?wsdl" method="opCreate" returnvariable="aString">
                    <cfinvokeargument name="Description" value="test"/>
                    <cfinvokeargument name="Requester_Login_Name" value="testLogin"/>
                    <cfinvokeargument name="Requester_Name" value="testRequester"/>
                    </cfinvoke>
                    <cfoutput>#aString#</cfoutput>
                    OR
                    <cfscript>
                    Ws=CreateObject("webservice"," http://oldtas184/arsys/WSDL/public/oldtas184/CHG_Change_WebService_OpCreate_DisplayOnly_v2 ");
                    </cfscript>
                    • 7. Re: Problem in Consuming a Web Service running on Remedy
                      Level 7
                      I am afraid I am not much of an expert at web services myself. Each
                      time I create and|or use one, I have to pull much hair and their isn't
                      much left to pull.
                      Maybe SOAP headers might help, but I have never used them.
                      One piece of advice I can give you is to just invoke the object and then
                      dump it. If you can get this far then you can proceed with using the
                      methods.
                      hange_WebService_OpCreate_DisplayOnly_v2?wsdl");
                      <cfdump var="#Ws#">
                      I believe you always want the "wsdl" parameter in your URI.
                      • 8. Re: Problem in Consuming a Web Service running on Remedy
                        Level 7
                        You may want to try the HouseOfFusion CF-Talk list.
                        ( http://www.houseoffusion.com/groups/cf-talk/). The smart people who
                        use that list provided me much help when I was working out the weather
                        web services
                        SandyVohra wrote:
                        • 9. Re: Problem in Consuming a Web Service running on Remedy
                          SandyVohra Level 1
                          Thanks All Guys!!
                          But try using CFHTTP in case you face this kinda problem again. Code below:
                          <cfsavecontent variable="testwsSoapRequest">
                          <cfoutput>
                          <soapenv:Envelope xmlns:soapenv=" http://schemas.xmlsoap.org/soap/envelope/"
                          xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance">
                          <soapenv:Body>
                          <Test xmlns="urn:testwebservice">
                          <Assigned_To>Demo</Assigned_To>
                          <Short_Description>Testing SOAP Post via HTTP</Short_Description>
                          <Submitter>Demo</Submitter>
                          </Test>
                          </soapenv:Body>
                          </soapenv:Envelope>
                          </cfoutput>
                          </cfsavecontent>
                          <cfhttp url=" http://<url to web service" method="post">
                          <cfhttpparam name="SOAPAction" type="HEADER"
                          value="urn:testwebservice"
                          <!--- send SOAP request in body --->
                          <cfhttpparam name="attachedDocument" type="body"
                          value="#testwsSoapRequest#">
                          </cfhttp>
                          • 10. Problem in Consuming a Web Service running on Remedy
                            disay_
                            Hi SandyVohra;
                            Did you ever find a solution to this issue? I am having the same problem.
                            Thanks.
                            Daisy.
                            • 11. Re: Problem in Consuming a Web Service running on Remedy
                              tomj Adobe Employee
                              Note that the problem reported in the original posting was that the Apache Axis WSDL2Java tool/library used by ColdFusion MX was throwing an error when trying to generate the code that ColdFusion uses to consume the web service.
                              This generally indicates a badly formed WSDL (use a WSDL 1.1 validation tool) or a bug in the code generator or both.
