have made this external preloader to load my 2mb .swf, and it
works but when u click on a button the wipe go across the screen
but it doesnt change the page as you can see this on this link
below
Text
but its supose to look like this example( if you clicked on
the installs button a 3d amimated wipe will go across the screen
then it will jump to the Installs page)
Text
and i dont know why
im using the flash 8 Slide presentation template as its
perfect for what im achive easy to and works fine with out the
external preloader but if i use the external preloader it stop the
buttons working by stoping them going to the next page
the code that tells flash to goto the correct slide is in the
movie clip where the image sequance of the wipe is and at the end
of the image sequance i have an action layer which is as follows
// GoTo Screen behavior
if((_root.application.Installs != undefined) &&
(_root.application.Installs != null))
var screen = null;
var target = this;
while((screen == null) && (target != undefined)
&& (target != null))
if(target instanceof mx.screens.Screen)
screen = target;
else
target = target._parent;
if(screen instanceof mx.screens.Slide)
screen.gotoSlide(_root.application.Installs);
// End GoTo Screen behavior
and my external preloader code is as follows
var mcl:MovieClipLoader = new MovieClipLoader();
var mclL:Object = new Object();
mclL.onLoadProgress = function(target, loaded,total) {
loader.percent.text = Math.round((loaded/total) * 100) + "%";
mclL.onLoadInit = function () {
loader._visible = false;
loader.percent.text = "";
mcl.addListener(mclL);
mcl.loadClip("kidpower_Web.swf",holder);
b1.onRelease = function() {
loader._visible = true;
b2.onRelease = function() {
mcl.loadClip("2_Web.swf",holder);
Thanks Martin
