11 Replies Latest reply on Sep 28, 2006 9:16 AM by kglad
    Preloader that changes external swfs every 5 seconds
    Edson_Correa
      HI,
      I've done an web banner in flash that loads an external swf and changes for another external swf after 5 seconds. The banner have a preloader, but the problem becomes when it loads the first time. As the swfs aren't cached in the browser's cache yet, the time for 5 seconds starts to count from the preloader, and when the external swf finally shows, only rest 1 second and it is changed to another. There is a way to "freeze" the time for each external swf until it totally loads?
      The code that loads the swfs every 5 seconds (this code is placed into an action layer):
      begin of code:
      var intervalId:Number;
      var count:Number = 0;
      var maxCount:Number = 23;
      var duration:Number = 0;
      var banners:Array = new Array(
      "abatrade.swf",
      "bancobrasil.swf",
      "caparao.swf",
      "cedro.swf",
      "cesama.swf",
      "copasa.swf",
      "damatta.swf",
      "emtel.swf",
      "engedrain.swf",
      "extel.swf",
      "feedback.swf",
      "iti.swf",
      "intermedium.swf",
      "magnesita.swf",
      "maquenge.swf",
      "maxxdata.swf",
      "orteng.swf",
      "paiva.swf",
      "paraibuna.swf",
      "paraopeba.swf",
      "sabesp.swf",
      "serpro.swf",
      "soll.swf",
      "thawte.swf"
      function executeCallback(param:String) {
      var duration:Number = 5000;
      loadMovie(banners[count],loadmovie_mc);
      loadmovie_mc._x=0;
      loadmovie_mc._y=0;
      clearInterval(intervalId);
      if(count < maxCount) {
      count++ ;
      intervalId = setInterval(this, "executeCallback", duration, banners[count]);
      else {
      count=0;
      if(intervalId != null) {
      //end of code
      And the code for the preloader (this code I place into the movieclip that loads the external swfs):
      //begin of code:
      onClipEvent(enterFrame) {
      var gtT:Number = this.getBytesTotal();
      var gtL:Number = this.getBytesLoaded();
      var gtP:Number = int((gtL/gtT)*100);
      if ( gtT > gtL ) {
      this._alpha = 0;
      _root.loader._alpha = 100;
      _root.loader.bar._width = gtP;
      } else {
      this._alpha = 100;
      _root.loader._alpha = 0;
      delete onEnterFrame;
      //end of code
      Note that I tryed to freeze the time using a clearInterval in the second code, but it simply don't works...
      Any Ideas? Thanks
      Edson
