2 Replies Latest reply on Sep 26, 2006 8:16 AM by azadisaryev
    beb0 Level 1
      Help please;
      I created a login page and it is working fine. Now what I'm trying to do is to display the user that is logged in into the index page. Any help please???
        • 1. Re: help??
          dnaguy Level 1
          The username is a session variable: #SESSION.MM_Username#
          You should be able to use this along with <cfoutput> to display the username.
          • 2. Re: help??
            azadisaryev Level 1
            which variable, if any, is available inside the session scope for the logged-in user's username depends on which login framework you are employing. it is not necessarily going to be session.mm_username at all...
            if you are employing CF7's login framework using <cflogin> and <cfloginuser> tags, the variable holding the username will be (again, likely, but not necessarily) #session.j_username#
            if you are employing a custom-made login framework, it is impossible to say whihch var holds your user's username without seeing your user authorization code... post it here and we will be able to help.
