7 Replies Latest reply on Sep 25, 2006 6:58 PM by Newsgroup_User
    Question about frames in Fireworks
    Level 7
      I have about 50 frames making a very small animated gif in fireworks.
      Everytime you play it it plays 1-50 and then starts right over at 1. I want
      it to play 1-50 and then go backwards from 50-1 and then loop this forever.
      How do I do this?
        • 1. Re: Question about frames in Fireworks
          Level 7
          > How do I do this?
          You need to add those 50 frames in reverse order. Well, techincally 48
          frames, as you probably do not need to have frames 1 and 50 repeated.
          Here's how:
          Select frames 2 - 49 in the frames panel.
          Go to the Frame Options icon and choose Duplicate
          Go to Commands > Document > Reverse Frames
          Set the start frame at 51 and the end frame at 98
          click ok.
          HTH
          • 2. Re: Question about frames in Fireworks
            Level 7
            Thanks a million Jim, that's exactly the answer I was looking for!
            "Jim Babbage" <jim@communitymx.com> wrote in message
            news:ef8sms$7k5$1@forums.macromedia.com...
            >> want it to play 1-50 and then go backwards from 50-1 and then loop this
            >> forever. How do I do this?
            > Here's how:
            > click ok.
            > HTH
            • 3. Re: Question about frames in Fireworks
              Level 7
              :-) You're very welcome.
              Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
              Extending Knowledge, Daily
              http://www.communityMX.com/
              CommunityMX - Free Resources:
              http://www.communitymx.com/free.cfm
              .:Adobe Community Expert for Fireworks:.
              news://forums.macromedia.com/macromedia.fireworks
              news://forums.macromedia.com/macromedia.dreamweaver
              >> Here's how:
              >> click ok.
              >> HTH
              • 4. Re: Question about frames in Fireworks
                Level 7
                One more question maybe you could answer for me Jim since I'm sort of new to
                animations... Is it possible for me to select a different start point in my
                frames? I have about 100 frames now and when I export them I want some of
                them to start at frame 1 and others to start at say frame 40 and loop
                forever. That way all the animations are esentially the same but don't look
                the same because they start at different frames... How do I do this?
                Thanks again!
                -Chris
                "Jim Babbage" <jbabbage@newmediaservices.ca> wrote in message
                news:ef9gea$3n3$1@forums.macromedia.com...
                >>> Here's how:
                >>> click ok.
                >>> HTH
                • 5. Re: Question about frames in Fireworks
                  Level 7
                  GIF animations are pretty simplistic. They go from frame 1 - to the last
                  frame of the animation. There is no way (as far as I know) they can be
                  started midway through the frames. If this is what you want to do, you'd
                  need to create several animation files, each one starting and ending
                  where you want THAT particular file to start an end.
                  I never asked before, but what are the pixel dimensions of your
                  animations? GIF animation file size is determined by three main things:
                  number of colors
                  pixel dimensions
                  number of frames
                  Generally, you want GIF animations to be either small in dimensions, or
                  frame count (or both) to keep file sizes low.
                  Can you give us a better idea of what you are trying to achieve and why?
                  You may be better off building these animations within Flash. You'll get
                  more flexibility and interactivity.
                  > Thanks again!
                  > -Chris
                  >>>> Here's how:
                  >>>> click ok.
                  >>>> HTH
                  • 6. Re: Question about frames in Fireworks
                    Level 7
                    Jim,
                    I need to teach myself Flash, it's one thing I haven't learned yet that I
                    really should. I need to find a good book or something on Flash. Anyways
                    my gif animations are about 20x20 pixels at the very most. Basically they
                    are little square buttons that turn from white to red over the period of
                    about 50 frames. Each frame is just a different shade of red until it gets
                    all the way to bright red. Then it just loops again. Understand what I
                    mean?
                    Thanks!
                    -Chris
                    news:ef9r7t$got$1@forums.macromedia.com...
                    > need to create several animation files, each one starting and ending where
                    > number of colors
                    > pixel dimensions
                    > number of frames
                    >> to animations... Is it possible for me to select a different start point
                    >> in my frames? I have about 100 frames now and when I export them I want
                    >> some of them to start at frame 1 and others to start at say frame 40 and
                    >> loop forever. That way all the animations are esentially the same but
                    >> don't look the same because they start at different frames... How do I do
                    >> this?
                    >> Thanks again!
                    >> -Chris
                    >>>>>> I want it to play 1-50 and then go backwards from 50-1 and then loop
                    >>>>>> this forever. How do I do this?
                    >>>>> Here's how:
                    >>>>> click ok.
                    >>>>> HTH
                    • 7. Re: Question about frames in Fireworks
                      Level 7
                      Yup understood. I doubt they're very big files then. What is reason
                      for starting the animation at different frames?
                      > Jim,
                      > mean?
                      > Thanks!
                      > -Chris
                      >> number of colors
                      >> pixel dimensions
                      >> number of frames
                      >>> this?
                      >>> Thanks again!
                      >>> -Chris
                      >>>>>> Here's how:
                      >>>>>> click ok.
                      >>>>>> HTH
