2 Replies Latest reply on Sep 23, 2006 12:59 PM by Newsgroup_User
    hide Taskbar?
    Level 7
      Hi all,
      I've created a couple of simple applications in Director MX that cycle
      between a selection of flash files.
      The Projector is set to play full screen, and is in windows startup to run
      when the pc is started (obviously!)
      The problem I am having is that when the pc starts up, the application plays
      with the taskbar on top! It only goes if i physically click on the
      application (which I cant do since the pc is being left for a week in
      location; restarting each morning).
      The task bar is NOT set to 'keep on top of other windows'. Ive also tried
      'auto-hide' but it still stays there
      I've also tried a buddyAPI function: baHideTaskBar( true ) - still no joy!
      Can anyone help? Am i missing something really simple here? (its been a long
      week with not much sleep!!)
      Cheers,
      Tim
        • 1. Re: hide Taskbar?
          Level 7
          I think i might have worked it out...
          It only seems to do it if i have a splash screen (ie a bmp file with the
          same name as the projector in the root).
          If i dont use a splash image, it all work fine?
          odd. anyone know why or a workaround?
          Cheers,
          Tim
          "Tim Dixon" <tim@keymtNOSPAMPLEASE.com> wrote in message
          news:ef34mr$dbu$1@forums.macromedia.com...
          > Hi all,
          > plays with the taskbar on top! It only goes if i physically click on the
          > long week with not much sleep!!)
          > Cheers,
          > Tim
          • 2. Re: hide Taskbar?
            Level 7
            It sounds like a bug that was fixed with MX 2004 whereby when the splash
            screen was removed on projector opening, the projector would be sent
            behind other open windows.
            You could either upgrade, or use Buddy API's
            baSetWindowState(baWinHandle(), "stayontop") in your #prepareMovie handler
