8 Replies Latest reply on Sep 26, 2006 7:15 AM by Newsgroup_User
    FW 8 pop up menu
    shonts
      Hello,
      I have done a navagation bar in fireworks, exported it and put it into my webnsite. I have used round trip editing to link menu items to relative pages within the site but it is just not working. I have floowed help menu and info I could find on net step by step still no joy can anyone help me?
      Thanks Shontelle
        • 1. Re: FW 8 pop up menu
          Level 7
          shonts wrote:
          > Hello,
          Can you post a URL?
          Linda Rathgeber [PVII] **Adobe Community Expert-Fireworks**
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          Design Aid Kits: http://www.webdevbiz.com/pwf/index.cfm
          • 2. Re: FW 8 pop up menu
            shonts Level 1
            Hi Linda thanks for your reply,
            URL: http://members.iinet.net.au/~sandjallwood@ozemail.com.au/index.html
            I just can't figure it out?? any help greatly appreciated.
            Shontelle
            • 3. Re: FW 8 pop up menu
              shonts Level 1
              sorry also should have said products is the one with drop down menu (signage,design, and printing)
              • 4. Re: FW 8 pop up menu
                shonts Level 1
                new quirk while linking to the intended pages (signage, design and printing) does not work I can link to other pages in the site (contact, home, about us ect.)
                If I select a page from the menu within in edit pop up menu dialog box, created by fireworks the links work but adding the adding a page (i.e design.html) does not
                Is there a way to get the pages I need to link to into the menu fireworks creates for selection??
                • 5. Re: FW 8 pop up menu
                  shonts Level 1
                  • 6. Re: FW 8 pop up menu
                    Level 7
                    <a href="Templates/signage.htm"
                    Your links are pointing within the Templates folder.
                    In the HTML code for your TEMPLATE file, change each of these links to look
                    like this -
                    <a href="../signage.htm"
                    and you should be OK.
                    By the way, playing with these menus and DW templates is dangerous. There
                    are much better and must less potentially troublesome ways to do such menus.
                    By the way #2, you have used a Flash headline on these pages, and that Flash
                    is being trapped by the recent IE6 updates. You can fix that if you are
                    using DW8, or by using this suggested method -
                    http://blog.deconcept.com/2005/03/31/proper-flash-embedding-flashobject-best-practices
                    Murray --- ICQ 71997575
                    (If you *MUST* email me, don't LAUGH when you do so!)
                    http://www.dreamweavermx-templates.com - Template Triage!
                    http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
                    http://www.dwfaq.com - DW FAQs, Tutorials & Resources
                    http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
                    "shonts" <webforumsuser@macromedia.com> wrote in message
                    news:ef8nkq$10c$1@forums.macromedia.com...
                    > Hello,
                    > pages
                    > info
                    > Thanks Shontelle
                    • 7. Re: FW 8 pop up menu
                      shonts Level 1
                      Hello Murray,
                      Thank you I will use your fix while i try to learn how to rebuild dropdown without fireworks when (if) I can acheive this I will replace fw version with newer version.
                      I am using dreamweaver 8 so i will look into fixing the ie6 issue.
                      Thanks again,
                      Shontellle
                      • 8. Re: FW 8 pop up menu
                        Level 7
                        Good luck.
                        news:efbbig$h5a$1@forums.macromedia.com...
                        > Hello Murray,
                        > dropdown
                        > with
                        > newer version.
                        > Thanks again,
                        > Shontellle
