• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Open a Socket Connection
New Here ,
Sep 27, 2006 Sep 27, 2006
I have an RFID reader that has an internal memory bank that stores rfid scans. From speaking to the company in order to get the data off I need to create a socket connection to port 8080 and send RQL (which is similar to sql) and then it will send me back piped results.
Can anyone assist me on how to open a connection to ip 192.168.1.139 port 8080 and send this
SELECT read_count, protocol_id, antenna_id, id FROM tag_id WHERE protocol_id='GEN2' set time_out=8000
and then output the results it returns.
Thanks in advance!
TOPICS
Advanced techniques
Views
424
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
I am using the below code found from another forum and it's working great... the issue is it's only returning one line.. I am however expecting more than that. Any suggestions?
<!-- begin code sample -->
<cfset serverStruct = structNew() />
<!-- the variables -->
<cfset serverStruct.serverIp = "192.168.1.139" />
<cfset serverStruct.serverPort = "8080" />
<cfset serverStruct.portConnected = "" />
<!--- Create the socket object --->
<cfset objSocket = CreateObject("java", "java.net.Socket") />
<!--- Connect --->
<cftry>
<!--- Set up socket to IP:port of remote server --->
<cfset objSocket.init(serverStruct.serverIp, serverStruct.serverPort)/>
<cfset serverStruct.portConnected = objSocket.isConnected()>
<!--- Did we connect? --->
<cfif serverStruct.portConnected>
<!-- create the string. Note the use of quotes to escape quotes in a string -->
<cfset mySendData = "SELECT id FROM tag_id WHERE protocol_id='GEN2';">
<!--- obtain the streams --->
<cfset input = objSocket.getInputStream()>
<cfset output = objSocket.getOutputStream()>
<!--- set up buffered reader for the socket; it will read character data
into a buffer until until enough of it can be processed efficiently. However,
a buffered reader reads a reader object, hence we first have to convert the
inputstream into a reader --->
<cfobject class="java.io.BufferedReader" name="brObj" action="CREATE" type="JAVA">
<cfobject class="java.io.InputStreamReader" name="isrObj" action="CREATE" type="JAVA">
<cfset streamReader = isrObj.init(input)>
<cfset dataBuffer = brObj.init(streamReader)>
<!--- send the data to the remote server --->
<cfobject class="java.io.PrintStream" name="pwObj" action="CREATE" type="JAVA">
<cfset writer = pwObj.init(output)>
<cfset sentData = writer.println(mySendData)>
<!--- Get the response from the server --->
<cfset response = dataBuffer.readLine()>
<!--- Close the streams and the connection --->
<cfset streamReader.close()>
<cfset dataBuffer.close()>
<cfset writer.close()>
<cfset objSocket.close()>
</cfif>
<cfcatch type="any">
something went wrong.
</cfcatch>
</cftry>
<cfdump var="#response#">
Votes
Translate
Translate
Report
Report
New Here ,
The answer is in your code:
take a look at the java docs for BufferedReader: http://java.sun.com/j2se/1.4.2/docs/api/java/io/BufferedReader.html
because readLine returns null if you are passed the last line ( http://java.sun.com/j2se/1.4.2/docs/api/java/io/BufferedReader.html#readLine()), you can do something like this:
<cfset sLines = "">
<cfset sLine = dataBuffer.readLine()>
<cfloop condition="#isDefined('sLine')#">
<cfset sLines = "#sLines##sLine#">
</cfloop>
<!--- now, sLines will contain all your lines of data--->
here is a java example of the same thing... http://www.cafeaulait.org/slides/intljava/2001ny/javaio/57.html
Votes
Translate
Translate
Report
Report
New Here ,
Sep 29, 2006 Sep 29, 2006
Thanks for your response, ok i've change the code to use the following, but now it just hangs... i.e. it looks like it's working in the browser but then just times out.
<cfsetting requesttimeout="1000">
<cfflush interval="5">
<cfset sLines = "">
<!--- Connect --->
<cftry>
<!---<cfset response = dataBuffer.readLine()>
<cfset sLines = "">--->
</cfloop>
</cfif>
</cfcatch>
</cftry>
<cfdump var="#sLine#">
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
maybe i am trying to do something coldfusion is not suppose to do.... but, I thought with the new event gateway's it was possible.
Basically I need to open a tcp port to about 6 devices and keep that port opened while receiving messages from the RFID reader.
Once a message is received it need to be inserted into a MS SQL database.
That's it...
Am i asking to much of CF?
Votes
Translate
Translate
Report
Report
Resources
Documentation
