I'm using Rh 2017. I had a "Gray Page Icon" and it started when I modified 'Conditional Build Expression'; no issues with Responsive HTML5.
Build Expression Before:
NOT HEFM AND NOT McKesson AND NoSpace AND NOT online AND NOT PFM (Note: I did not use the "NOT" after the 'AND" before 'NoSpace')
Build Expression Corrected After:
NOT HEFM AND NOT McKesson AND NOT NoSpace AND NOT online AND NOT PFM
A grey icon means the topic is excluded from the output by the expression. That's it.
You seem to be saying that using the same expression in both outputs, in responsive the topic is included but not in print, correct? That cannot be.
Double check that the expression being used is the same in both and generate both to an empty folder so that there is no clutter from a previous generation.
See www.grainge.org for free RoboHelp and Authoring information.
