1 Reply Latest reply on Sep 26, 2006 3:59 PM by TimSymons
    New Window to specific size
    sheep-ish Level 1
      I did a search through the forum and found what I thought was the perfect answer to my problem - to have a new window open to a certain size etc.
      Attached is the code. Can anyone see what may be going wrong.
      Dave
        • 1. Re: New Window to specific size
          TimSymons Level 1
          Couple of things I noticed.
          1. You are not concating your strings together correctly. You need to use the "+" to do that.
          2. Why define a JS function in the getURL call. Just use the window.open command directly.
          try using this in your getURL: (by the way, you do realize that this will only attach this script to your button then you will have to click on the "panel.thumb_12" to launch the window)
