1 Reply Latest reply on Jan 5, 2009 5:22 AM by Günter Schenk
    addt validation problem
    David Wu Level 1
      Hi
      addt url validation will not let the address pass if it have variable
      such as
      http://www.xxx.com?a=1
      but it's should be a normal web address isn't it?
        • 1. Re: addt validation problem
          Günter Schenk Level 4
          Hi chan15,
          don´t know if this info will really help you, however :: all of ADDT´s default validation rules are defined in the file "includes/tng/triggers/tNG_FormValidation.class.php", and in here you´ll find the variable $arr["text"]['url']['regexp'] which has a pretty complex regular expression assigned as value.
          It seems that the developers did create this regular expression in accordance to the official "Uniform Resource Identifier" (URI) specification (http://tools.ietf.org/html/rfc3986), so it´s probably even somewhat correct -- however I agree that the existing regex might just be too strict for your purposes, so I´d suggest to rather make use of a custom regex which is less restrictive than the default one.
          Cheers,
          Günter Schenk
          Adobe Community Expert, Dreamweaver
