0 Replies Latest reply on Mar 18, 2009 9:12 AM by (antoniod)
    [dynamic form] file fields and multiple records insert problem
    Level 1
      Hi all,
      I created a dynamic list/form to udate a mysql table.
      The dynamic form contains a file field.
      When I insert, say, 6 records at once, the dynamic form is displayed as a
      list that allow you to copy down field content on the below fields.
      But this feature is not present for file field. Why?
      What to do when you need to use the same file for all records you're
      inserting?
      If you select the same file for every single record, the insert transaction
      will upload multiple copies of the same file (file, file_1,
      file_2...file_6). This is a problem when using 4000+ files.
      Is there a workaround?
      TIA
      tony
