2 Replies Latest reply on May 22, 2007 8:35 AM by jefferisp7
    Forgot Password error
    jefferisp7 Level 1
      Can someone help me interpret this error on password request. Can't tell if
      it is an email server problem or a db error. :
      Error:
      Internal error.
      Developer Details:
      Specified Primary Key Column is different from the one set in InterAKT
      Control Panel > Login Settings > Database. (FORGOTPASS_WRONG_PK)
      tNG Execution Trace - VIEW
      tNG_update.executeTransaction
      STARTER.Trigger_Default_Starter
      tNG_update.doTransaction
      BEFORE.Trigger_Default_saveData
      tNG_update.saveData
      BEFORE.Trigger_Default_FormValidation
      BEFORE.Trigger_ForgotPasswordCheckEmail*<<<<<<
      ERROR.Trigger_UpdatePassword_AddPassword
      ERROR.Trigger_UpdatePassword_RemoveOldPassword
      tNG_update.getRecordset
      tNG_update.getFakeRsArr
      tNG_update.getLocalRecordset
      tNG_update.getFakeRecordset
        • 1. Re: Forgot Password error
          jefferisp7 Level 1
          On 5/22/07 11:11 AM, in article C278806C.55A34%jefferis@petersonsales.net,<br />"Jefferis Peterson" <jefferis@petersonsales.net> wrote:<br />This is the table syntax, if that helps:<br /><br />CREATE TABLE `admin_usr` (<br />  `id` int(100) NOT NULL auto_increment,<br />  `username` varchar(35) NOT NULL default '',<br />  `password` varchar(10) NOT NULL default '',<br />  `email` varchar(30) default NULL,<br />  `random_usr` varchar(32) default '',<br />  `active_usr` tinyint(4) NOT NULL default '1',<br />  `accessLevel` tinyint(2) NOT NULL default '1',<br />  PRIMARY KEY  (`id`)<br />) ENGINE=MyISAM DEFAULT CHARSET=utf8<br />>
          • 2. Re: Forgot Password error
            jefferisp7 Level 1
            On 5/22/07 11:11 AM, in article C278806C.55A34%jefferis@petersonsales.net,<br />"Jefferis Peterson" <jefferis@petersonsales.net> wrote:<br /> <br />> Specified Primary Key Column is different from the one set in InterAKT<br />> Control Panel > Login Settings > Database. (FORGOTPASS_WRONG_PK)<br /> <br />In my KT Login Settings, the primary key is set to "id"  which corresponds<br />to the dababase's auto increment field id, which is an int  field.   In the<br />session the id table column is set to session variable name kt_login_id.<br /><br />Bonky! What's wrong here?
