This content has been marked as final.
Show 7 replies
1. Re: Multiple Upload Image Problem - Resize GIF files
Günter Schenk Sep 9, 2007 2:42 PM (in response to oicram)Hi Marcio,
hope this is not a stupid question, lol :: do you actually have imagemagick installed as php module and defined it as ADDT´s "preferred library" ?
Günter Schenk
Adobe Community Expert, Dreamweaver -
2. Re: Multiple Upload Image Problem - Resize GIF files
oicram Sep 9, 2007 3:02 PM (in response to oicram)Yes. The module is on the host, and yes imagemagick is installed as preferred library.
I'm using now GD library. Some files get more compressed. But I think I prefer the quality of imagemagick.
Can you tell me the inconveniance of using GD instead of Imagemagick, or its, shortly similar?
Thanks -
3. Re: Multiple Upload Image Problem - Resize GIF files
Günter Schenk Sep 9, 2007 3:26 PM (in response to oicram)Hi Marcio,
sorry, but never worked with ImageMagick so far, so I can´t compare
The "quality" parameter works only for jpeg and .png files as described here
yeah, it seems that this is a small bug in ADDT´s "includes/common/lib/image/KT_Image.class.php" file. Was just checking the code in there, and indeed it adds this extra parameter regardless the image type -- but I do have an idea how this file can be modified to not use this parameter if the file in question has the suffix ".gif".
If you feel a little adventurous, I´ll happily invite you to modify some code in this file -- please let me know if you´re ready for some instructions. However, if so, please make a backup of this file first...
Günter Schenk
4. Re: Multiple Upload Image Problem - Resize GIF files
oicram Sep 10, 2007 12:40 AM (in response to oicram)If
with imagemagick the quality/compression are must better
Then
I will be hapy to make the adventure and learn a little more
else
Well... maybe later.
Sorry for this kind of IF Statement post, I'm a little obsessed here by a specific script that I will post here.
Thanks for been here, you already a reference in this forum hm? :) -
5. Re: Multiple Upload Image Problem - Resize GIF files
Günter Schenk Sep 10, 2007 2:44 AM (in response to oicram)Hi Marcio,
if ($wanna_process_gifs_with_imagemagick == 'yes'){
$my_response = "Günter, now let me know !";
else {
$my_response = "forget it !";
GD isn´t bad either, it´s just ADDT´s default image quality setting of 80% which might not be sufficient to you. However, this is something you can change in the file "includes/common/KT_config.inc.php" -- you´ll see an array of parameters in there, and one of them reads:
$KT_default_image_quality = "80";
If it´s not in there, please add this line in between -- and as you might guess, setting the value to 100 will instruct ADDT to always leave the image quality "as is".
Günter Schenk
6. Re: Multiple Upload Image Problem - Resize GIF files
oicram Sep 10, 2007 3:01 AM (in response to oicram)LOL
Perfect :)
Thanks a lot. I will use GD instead. If for some reason in the future I must use imagemagick I call back here, or maybe the bug is corrected with the ADDT team. :)
Thanks for the $KT_default_image_quality tip. -
7. Re: Multiple Upload Image Problem - Resize GIF files
Günter Schenk Sep 10, 2007 3:13 AM (in response to oicram)Hi Marcio,
I think that so far noone seemed to have stumbled across this bug, because the vast majority of web hosts don´t have Imagemagick installed.
Cheers,
Günter Schenk
