2 Replies Latest reply on Nov 26, 2007 3:06 PM by (Laurence_Lewis)
    Can't Delete folder
    (Laurence_Lewis)
      I am working out how to get the "Multiple File Upload" working so that the data is also entered into the DB. I did a few tests and set the rename rule to be the same as the logged in person.
      How do I delete the test folders and files, I tried manually, I get a permission denied error.
      Duringthe test the data did not enter the DB so I can't use the "Delete File/Folder" option as there is no record.
      How do I delete the folder/Files from my server??
      Any help is appreciated
      Laurence
        • 1. Re: Can't Delete folder
          Günter Schenk Level 4
          Hi Laurence,
          please open the file "includes/common/KT_config.inc.php" and check the values of the two variables $KT_file_mode and $KT_folder_mode.
          They both should provide a default value of 755, but it might well be that you´ll need to set it to 777.
          Cheers,
          Günter Schenk
          Adobe Community Expert, Dreamweaver
          • 2. Re: Can't Delete folder
            (Laurence_Lewis) Level 1
            Hi Günter
            I tried changing the permissions with no luck, I still get a permission error when trying to physically delete the folder. I will try setting up a delete folder page and see what happens.
            Cheers
            Laurence
