This content has been marked as final.
Show 2 replies
1. Re: SPRY XML Dataset Get Schema
(ionut_moicianu) Jun 19, 2007 1:50 AM (in response to roborino3)Hello,
The error usually means that the XML source that you choose within Spry XML Data Set interface is not valid.
So you should check the XML source to see if it returns a valid XML.
Regards,
Ionut -
2. Re: SPRY XML Dataset Get Schema
roborino3 Jun 20, 2007 4:19 AM (in response to roborino3)Thanks for the response...I have checked the XML source and it is correct/valid. This use to work, it now no longer works.
Rob
