0 Replies Latest reply on Jan 16, 2008 10:39 AM by Waleed Barakat
    :: New Discovered Trick :: "Show_thumbnails" SB ::
    Waleed Barakat Level 1
      hello every one.
      - If you annoyed about the auto Resized thumbnails name that automatically created with the Resize Dimensions name when using show_thumbnails SB. this auto created name looks like this:
      let`s say our image name flowers.jpg or other extension it doesn`t matter here.
      so the thumbnails name will be flowers_80x80.
      that is too annoying specially when you want to use this auto created thumbs in the forums that uses [bbCode] as a link to the original full image. - Now if you point to the thumbnails file name within the thumbnails Folder using the [bbcode] code:
      [url=http://$sitename/uploads/$image_name][img]http://$sitename/uploads/thumbnails/$image _name[/img][/url]
      - then the dimensions 80x80 after the thumbnails name will link you to nothing.
      ** the solution:
      - Open the includes folder goto >>> tng >>> triggers >>> tNG_DynamicThumbnail.class.php
      - Switch to code view.
      - Browse down to line 442.
      - The original code looks like this:
      - $thumbnailName = $path_info['filename'].'_'.$width.'x'.$height.(isset($path_info['extension'])?'.'.$path_i nfo['extension']:'');
      * All what you have to do is to remove the logic that creats the resize dimensions after each created thumbnail so it must looks like this after removing the logic:
      - $thumbnailName = $path_info['filename'].(isset($path_info['extension'])?'.'.$path_info['extension']:'');
      - Now goto the thumbnails Folder and delete all old created thumbnails(Don`t worry it will be recreated automatically after opning any page contains show_thumbnails SB).
      - Open any page contains show_thumbnails and see the different. no you can use it as a direct link.
      *** don`t forgot to backup your original file before doing any changes...
      - for more dreamweaver developer toolbox please visit:
      - www.developer-online.com
      Have a nice time
      waleed bartakat
