3 Replies Latest reply on Jan 22, 2008 2:01 PM by Günter Schenk
    Validating Input/Formatting Output and general security.
      I'm looking for some general advice regarding securing my ADDT application. using the validation form behaviour should I be adding validation formats for all of the fields? at the moment I am validating phone number, zip codes and email addresses etc but not simple alpha-numerics like names and addresses. Should I be building a regular expression for these fields? I'm surprised they are not included as standard if that is the case? presumably if I don't add a validation format here then any input can be given including potential XSS vulnerabilities?
      Also I have a description input textarea using an RTE (Tiny_MCE) so obviously HTML must be allowed but how can I restrict certain tags and attributes like <script> "style" etc (Ideally a whitelist of tags would be preffered.
      Lastly when outputting data from the bindings tab should I be running any functions to secure the output? I've noticed KT_escapeAttribute() is being run to set default values for form fields. Should I be running this on all my output?
      Thanks folks.
        • 1. Re: Validating Input/Formatting Output and general security.
          Günter Schenk Level 4
          Hi Andrew,
          I´m using alpha or alpha-numeric regular expression all the time with regular input fields, and those regex´s are quite simple to create.
          Well, simply because there is no "standard", all the more a german or italian name and address differs pretty much from a US address, and they also use additional chars which can´t be covered by e.g. the regular "a-zA-Z" regex.
          Also I have a description input textarea using an RTE (Tiny_MCE) so obviously HTML must be allowed but how can I restrict certain tags and attributes like ------
          ADDT form validation routines don´t work with RTE editors in general, because they can´t -- once you implement e.g. TinyMCE, the regular HTML textarea is "overwritten" with some IFRAME, means that ADDT considers the textarea empty. That said, you´ll have to impose the required restrictions by excluding certain stuff from the editor´s list of "allowed tags".
          Cheers,
          Günter Schenk
          Adobe Community Expert, Dreamweaver
          • 2. Re: Validating Input/Formatting Output and general security.
            Level 1
            Thanks Günter,
            Could I use the convert to XHTML feature of ADDT (I understand this uses Tidy) in this case?
            • 3. Re: Validating Input/Formatting Output and general security.
              Andrew,
              I strongly doubt that, because ADDT has no clue that a RTE editor has been added and what its "virtual IFRAME" contains -- all ADDT can handle, is the contents of the existing standard textarea, but this one remains empty when replacing it with whatever RTE editor.
              Cheers,
              Günter Schenk
