1 Reply Latest reply on Mar 6, 2008 11:45 AM by Günter Schenk
    default value as a url variable
    Level 1
      I created an insert record form. One of the columns is hidden with the default value "{GET.inv_number}".
      This was automatically generated when I selected the default value to equal the url variable inv_number.
      code:
      $ins_invoice_items->addColumn("items_inv_id", "STRING_TYPE", "POST", "items_inv_id", "{GET.inv_number}");
      the link to this page is add.item.php?inv_number="value from previous page"
      right now it is add.item.php?inv_number=1
      The default value for column items_inv_id is not reading the variable.
      I have tried creating it manually $inv_number = $_GET['inv_number'];
      the code then looks like this:
      $ins_invoice_items->addColumn("items_inv_id", "STRING_TYPE", "POST", "items_inv_id", $inv_number);
      Still no value.
      If I write <?php echo $inv_number; ?> in the body, the value of 1 shows up.
      Why isn't dev toolbox reading this variable?
      Scott
        • 1. Re: default value as a url variable
          Günter Schenk Level 4
          Hi Scott,
          I *think* you´re having a conflict here -- if your hidden field "items_inv_id" already contains that URL variable, the default "addColumn" line...
          $ins_invoice_items->addColumn("items_inv_id", "STRING_TYPE", "POST", "items_inv_id");
          ...should be sufficient, as it´s supposed to grab the value from that field.
          Whenever I´m inserting some value that´s derived from an URL variable, I actually bypass any related hidden field and do that directly, e.g.
          $ins_invoice_items->addColumn("items_inv_id", "STRING_TYPE", "GET", "inv_number");
          Cheers,
          Günter Schenk
          Adobe Community Expert, Dreamweaver
