1 Reply Latest reply on Apr 27, 2008 2:13 PM by (Paul_B._Kelley)
    MySQL error
      I am completing the contacts management tutorial and in the final exercise using the QuB I get the following error:
      "You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'ORDER BY name_con' at line 1"
      This is interesting because you are instructed to remove the "ORDER BY name_con" from the SQL query (pg. 62) because, according to the author, "This step makes the query easier to view when you open MX Query Builder." Any ideas on why the error is generated? I was nearly done with my first ADDT tutorial and all had gone well up to this point!!!
