This content has been marked as final.
Show 7 replies
1. Re: Checkboxes in Insert Record Transaction
(cdembek) Jul 15, 2007 1:37 PM (in response to oicram)I found the same issue.. what I had to do is pass the no value to another page in a hidden field in order to insert the no value in the db.. but there has to be a better way -
2. Re: Checkboxes in Insert Record Transaction
oicram Jul 16, 2007 1:08 AM (in response to oicram)Instead of using 'yes' and 'no', now i'm using 'yes' and null.
I agree it should exist a better way.
Anyone please?!! -
3. Re: Checkboxes in Insert Record Transaction
(cdembek) Jul 16, 2007 4:51 PM (in response to oicram)funny today I used a check box 'Y' and 'N' default values and everything works fine -
4. Re: Checkboxes in Insert Record Transaction
oicram Jul 17, 2007 3:04 AM (in response to oicram)Yes, with 'Y' and 'N' it works, since we have that option in the insert transaction. But 'Yes' 'No, or, 'Oui' 'Non', or 'Sim' 'Não' that does not work. :S and thats the problem, I'd like to solve this. -
5. Re: Checkboxes in Insert Record Transaction
Günter Schenk Jul 17, 2007 4:05 AM (in response to oicram)Hi folks,
just FYI, ADDT has been designed to work with the following checkbox value options:
Y,N
1,0
-1,0
In case you want to display those values in a "user friendly" way on a certain page, just use ADDT´s "Show If conditional region" server behaviour with the following condition:
if:
"expression 1" (let this one point to the respective Y/N field from your recordset) == "expression 2" (Y)
Oui
activate the "has ELSE" option
Non
Günter Schenk
Adobe Community Expert, Dreamweaver -
6. Re: Checkboxes in Insert Record Transaction
oicram Jul 17, 2007 5:01 AM (in response to oicram)Thanks Günter,
Anyway I prefer if the checkboxes can handle enum data types, so he can accept other values without using extra code.
Its not a big issue, we can easily work around, but I think there is a bug in the ADDT when we put a default value to "no" and he cannot insert that "no" value in the database, and put null instead.
Or, if its not a bug, what does the defaut value in the insert record transaction for, cas,IMMO the help documents should be more complete concerning the transactions (without the wizards).
Good day, and thanks for answering. -
7. Re: Checkboxes in Insert Record Transaction
Günter Schenk Jul 17, 2007 8:14 AM (in response to oicram)Hi Marcio,
I saw that you now posted this question to the Interakt forums as well -- however, the way ADDT respectively it´s predecessor MX Kollection handles fields which have been declared "checkbox", restricts this field type to the above mentioned options.
...but I think there is a bug in the ADDT when we put a default value to "no" and he cannot insert that "no" value in the database, and put null instead
yeah sure, but that´s how ADDT has been conceived in this respect - what can I say ? :-D
However, in all those years I´m using it now, I managed to accustom myself to this specification and either used the field type "Menu" or "Radio Group" and provided the desired "yes/no" values as static options
Günter Schenk
