4 Replies Latest reply on Apr 29, 2008 7:30 AM by (Paul_B._Kelley)
    MySQL question regarding default values
    Level 1
      For the contacts management tutorial the contacts table ('contact_con') lists data for names as:
      `name_con` varchar(50) NOT NULL default ''
      However, in the PHPAdmin panel the "default" field is referenced by a footnote which reads: "For default values, please enter just a single value, without backslash escaping or quotes, using this format: a
      Does this mean that the default field is simply left blank, or as PHPAdmin puts it, left blank "without [...] quotes"? If so, why include these quotes in the SQL dump?
        • 1. Re: MySQL question regarding default values
          Günter Schenk Level 4
          Hi Paul,
          without the '' (which is an alias for "blank") quotes MySQL will throw an error
          Cheers,
          Günter Schenk
          Adobe Community Expert, Dreamweaver
          • 2. Re: MySQL question regarding default values
            Level 1
            Exported contacts table as created by using the PHPadmin gui interface:
            CREATE TABLE IF NOT EXISTS `contact_con` (
            `id_con` int(11) NOT NULL auto_increment,
            `idcom_con` int(11) NOT NULL default '0',
            `name_con` varchar(50) NOT NULL,
            `job_con` varchar(100) NOT NULL,
            `email_con` varchar(255) NOT NULL,
            `phone_con` varchar(30) NOT NULL,
            `birthday_con` date default NULL,
            PRIMARY KEY (`id_con`)
            ) ENGINE=MyISAM DEFAULT CHARSET=latin1 AUTO_INCREMENT=12 ;
            If this is incorrect, how does one enter a blank default value in the values field 'for 'name_con' (for instance) by using the PHPadmin gui, when it specifically instructs not to use quotes for this field?
            • 3. Re: MySQL question regarding default values
              Paul,
              *if* you specify a default blank value for text columns (e.g. varchar) in your sql dump, you will have to use those quotes, and that´s the correct way to do that -- but it´s of course up to you to omit specifying a default blank default value.
              Providing an SQL dump that´s going to be inserted into PhpMyAdmin is different from how things can be specified when working with PhpMyAdmin directly.
              just leave the default value field empty, and PhpMydmin will care for the rest.
              because you don´t have to add those quotes when working with PhpMyAdmin directly :-)
              Cheers,
              Günter Schenk
              • 4. Re: MySQL question regarding default values
                Level 1
                Thanks, Gunter, that's what I figured. I appreciate your patience.
