8 Replies Latest reply on Jun 12, 2008 9:04 PM by (Oriyomi_Shokunbi)
    ADDT Error
      I am Working on a webpage that list dynamically and links to updateable page.
      I got the error below, can any one help me trouble shoot where the likely problem is
      Error:
      Internal error.
      Developer Details:
      tNG_multipleUpdate.getLocalRecordset:
      Error message:
      You have an error in your SQL syntax near 'join,pix,date,sn, sn as kt_pk_department FROM department WHERE sn=1' at line 1
      SQL statement:
      SELECT dept,intro,detail,join,pix,date,sn, sn as kt_pk_department FROM department WHERE sn=1. (MUPD_RS)
      tNG Execution Trace - VIEW
      tNG_multipleInsert.executeTransaction
      STARTER.Trigger_Default_Starter
      tNG_multipleUpdate.executeTransaction
      tNG_multipleDelete.executeTransaction
      tNG_multipleUpdate.getRecordset
      tNG_multipleUpdate.getLocalRecordset*
      Yomi ;)
        • 1. Re: ADDT Error
          Günter Schenk Level 4
          Hi Yomi,
          "join" is one of the reserved words you can´t use for MySQL table and column names
          Cheers,
          Günter Schenk
          Adobe Community Expert, Dreamweaver
          • 2. Re: ADDT Error
            Level 1
            Thanks Gunter,
            It worked,
            How do one identify when an error is due to MySQL Reserved words?
            I mean looking at specific error triger
            Best Regards
            Yomi
            • 3. Re: ADDT Error
              Hi Yomi,
              in most cases the "You have an error in your SQL syntax near" error message already indicates that the first mentioned column name following "near" is the possible troublemaker -- MySQL always stops here and displays the column name it stumbles across, and in this case it´s "join".
              However, as this error message might not always be related to having used a reserved word, it´s recommended to compare your column names against a list of reserved words provided on a page like this: http://www.htmlite.com/mysql002a.php
              Cheers,
              Günter Schenk
              • 4. Re: ADDT Error
                Level 1
                Hi
                I am working on a insert record page and I got this error near text. but I did not name any field text. The id is not a reserved word.
                Pls what is the solution in this case?
                I am Error:
                Internal error.
                Developer Details:
                tNG_fields.getFakeRecordset:
                SQL error: Error creating temporary table:
                You have an error in your SQL syntax near 'TEXT, id TEXT)' at line 1
                SQL:
                CREATE TEMPORARY TABLE KT_fakeRS_20080612 (title TEXT, username TEXT, password TEXT, first TEXT, last TEXT, email TEXT, gender TEXT, homeadd1 TEXT, homeadd2 TEXT, city TEXT, residencestate TEXT, residencecountry TEXT, trnxID TEXT, RegDate TEXT, info TEXT, pix TEXT, foreign TEXT, id TEXT) (FIELDS_FAKE_RS_ERROR)
                tNG_insert.executeTransaction
                tNG_insert.getRecordset
                tNG_insert.getLocalRecordset
                tNG_insert.getFakeRecordset*
                Thanks for bn there
                • 5. Re: ADDT Error
                  Hi Yomi,
                  ...but "foreign" is reserved.
                  Cheers,
                  Günter Schenk
                  • 6. Re: ADDT Error
                    Level 1
                    Interesting!
                    Thanks a lot.
                    Yomi
                    • 7. Re: ADDT Error
                      Level 1
                      Yomi,
                      Please read this thread:
                      http://www.adobeforums.com/webx/.59b57554
                      I don't recommend ever using single words for database field names. If you use a naming convention, you will avoid all these problems you are having with reserved words.
                      Shane
                      • 8. Re: ADDT Error
                        Level 1
                        Thanks Shane,
                        That was insightful.
                        Yomi
