1 Reply Latest reply on Jun 21, 2008 9:48 PM by (rmeasy)
    ADDT Dependent Drop Down
      I have a dependent drop down set-up on a edit page. the detail drop down is not required so if i load a page with data with the the Master Drop down that has predefined option selected but the Detail drop has none, the detail drop has no options in it. The only way to get options in the detail drop is to change the master. Is there a way to invoke the the detail options dependency on the page load??
        • 1. Re: ADDT Dependent Drop Down
          I think that NO because you must select some item on the master drop down to populate the detail drop down.
          Still in this case, how your form will know what to show on the detail drop down?
          If you want to make something when page loads, you have to create a starter trigger.
