3 Replies Latest reply on Jun 16, 2008 8:38 AM by (shane_mosier)
    [php - mysql] how to capitalize an insert form text field?
      Hi all,
      I have an insert form on a page and I would like to correct the user
      input before inserting the data in the db.
      Example:
      the user inputs: CAR
      and Car will be inserted in the db.
      How can I do with ADDT?
      TIA
      tony
        • 1. Re: [php - mysql] how to capitalize an insert form text field?
          Günter Schenk Level 4
          Hi Tony,
          the PHP functions which will first convert a string to lowercase and then capitalize the first char would go like this:
          ucfirst(strtolower($bar));
          Please try embedding the following code in a Custom Trigger (type: BEFORE):
          $first_to_upper = ucfirst(strtolower($tNG->getColumnValue("column_name")));
          $tNG->setColumnValue("column_name", $first_to_upper);
          ...and replace "column_name" with the name of the column you´re inserting into the DB.
          Cheers,
          Günter Schenk
          Adobe Community Expert, Dreamweaver
          • 2. Re: [php - mysql] how to capitalize an insert form text field?
            Level 1
            tony,
            You would need to create an ADDT Custom Trigger set to execute BEFORE the Insert Transaction on your Insert page.
            It would look some thing like this:
            function Trigger_Custom(&$tNG) {
            // This code grabs the value for the form field "first_name"
            // from the submitted form and sets it to $firstName
            $firstName = $tNG->getColumnValue("first_name");
            // Now do your data processing on this value, in this case
            // the code coverts the string $firstName to upper case letters
            $firstName = strtoupper($firstName);
            // Now update the value for the column "first_name" before
            // the data is inserted into the database
            $tNG->setColumnValue("first_name", $firstName);
            Remember to be sure this Custom Trigger is set to execute BEFORE the Insert Transaction.
            Shane
            • 3. Re: [php - mysql] how to capitalize an insert form text field?
              Level 1
              thanks gunter and shane.
              it works.
              ciao ;).
              tony
