4 Replies Latest reply on Aug 1, 2008 7:16 AM by (eclipsme)
    Too many files
      I just installed the toolkit with DW CS3. I decided just to play around
      a bit, opened an existing page and began the Update Record Form Wizard.
      Suddenly I had dozens of new folders, files, and ftp activity - all
      before I actually placed anything.
      Is this normal? Flipped me out. I had to go through the site and delete
      everything. Please tell me I did something wrong, or at least why this
      is a good thing.
      Harvey
        • 1. Re: Too many files
          mohnkhan Level 1
          Ahh I belive you mean the .. include folders right ?
          if u added something from adobe spry then it will create dozens of files into the spry assets folder.
          if it was something else... check if u have any other plugin/ behaviour installed in dreamweaver..
          It should be normal..
          ftp activity is to test ur site.
          if u have local test then it shouldn't happen..
          if its something suspicious and ur on windows then check for viruses..
          Hope this helps..
          mohnkhan
          • 2. Re: Too many files
            Level 1
            > Hope this helps..
            > mohnkhan
            hmm... so not the usual behavior then. No, I do not use spry. There was
            more than just the includes folder, but not sure what else now. I shall
            have to explore further.
            Harvey
            • 3. Re: Too many files
              mohnkhan Level 1
              Welcome and be carefull of specially HTML pests (i mean stupid viruses ) which destroy our source code... Nasty ones..
              and remember to keep backups..
              mohnkhan
              http://www.mohitech.com
              • 4. Re: Too many files
                Level 1
                > Thanks
                > mohnkhan
                Right, but I don't think that is what is going on here. In any event, I
                will probably create some test site to play with this again and see what
                happens.
                Harvey
