8 Replies Latest reply on Aug 6, 2008 7:15 AM by Günter Schenk
    Insert validation BEFORE not working
      I have an insert/update form where I've added a Build Condition to the Validation Form server behavior. For reason its not working.
      What I need to happen is that when I click the submit button, if there are 2 or less recordsets with the same time (a field in the test table), then an error should appear and the form should not submit.
      On this form, I have this recordset:
      SELECT COUNT(*) as cnt
      FROM test
      So, in the Validation Form server behavior Build Condition I have {Recordset1.cnt} >= 2
      Regardless what I do, the form submits. Am I missing something obvious?
      I've tried changing the >= to <= and I've added a WHERE test.time = time variable but nothing has worked so far with the Build Condition.
      Please help!
        • 1. Re: Insert validation BEFORE not working
          Günter Schenk Level 4
          Hi Peter,
          I *think* you could as well use the $totalRows_queryname variable
          Cheers,
          Günter Schenk
          Adobe Community Expert, Dreamweaver
          • 2. Re: Insert validation BEFORE not working
            Level 1
            Thanks Gunter.
            My question is where would I use this ($totalRows_queryname variable)?
            I've added this to my recordset code but its not being recognized. I hope I'm missing something obvious. Below is my recordest.
            $numtest_Recordset1 = "-1";
            if (isset($_POST['num_test'])) {
            $numtest_Recordset1 = $_POST['num_test'];
            mysql_select_db($database_sailing, $sailing);
            $query_Recordset1 = sprintf("SELECT COUNT(*) as cnt FROM test WHERE test.num_test = %s", GetSQLValueString($numtest_Recordset1, "int"));
            $Recordset1 = mysql_query($query_Recordset1, $sailing) or die(mysql_error());
            $row_Recordset1 = mysql_fetch_assoc($Recordset1);
            $totalRows_Recordset1 = mysql_num_rows($Recordset1);
            if($totalRows_Recordset1 == 4) {
            $error = new tNG_error("Timeslot is filled!",array(),array());
            return $error;
            • 3. Re: Insert validation BEFORE not working
              Peter,
              is this an additional recordset which is supposed to "capture" the result of ADDT´s multiple insert/update transaction recordset ? If so, I fear you won´t get any results, because your current variable $_POST['num_test'] would have to capture an array of values (from the transaction recordset) rather than one single value -- and I fear that this additional recordset lacks some sort of "connection" to the transaction recordset, which is the one you would have to examine.
              I don´t have any other answer right now, but it could be helpful to see the whole page code posted as .txt file on your server.
              Cheers,
              Günter Schenk
              • 4. Re: Insert validation BEFORE not working
                Level 1
                The array definitely sounds like the way I should go. How, I still need some guidance. As far as the recordset that captures the $_POST and compares it to the recordset above, all the data is in the same db table. <br /> <br />Here's the code from my page. Thanks for your help so far! I think we're close! <br /><?php require_once('../Connections/sailing.php'); ?> <br /><?php<br />// Load the common classes<br />require_once('../includes/common/KT_common.php');<br /><br />// Require the MXI classes<br />require_once ('../includes/mxi/MXI.php');<br /><br />// Load the tNG classes<br />require_once('../includes/tng/tNG.inc.php');<br /><br />// Load the KT_back class<br />require_once('../includes/nxt/KT_back.php');<br /><br />// Make a transaction dispatcher instance<br />$tNGs = new tNG_dispatcher("../");<br /><br />// Make unified connection variable<br />$conn_sailing = new KT_connection($sailing, $database_sailing);<br /><br />// Start trigger<br />$formValidation = new tNG_FormValidation();<br />$tNGs->prepareValidation($formValidation);<br />// End trigger<br /><br />if (!function_exists("GetSQLValueString")) {<br />function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "") <br />{<br />  $theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;<br /><br />  $theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);<br /><br />  switch ($theType) {<br />    case "text":<br />      $theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";<br />      break;    <br />    case "long":<br />    case "int":<br />      $theValue = ($theValue != "") ? intval($theValue) : "NULL";<br />      break;<br />    case "double":<br />      $theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";<br />      break;<br />    case "date":<br />      $theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";<br />      break;<br />    case "defined":<br />      $theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;<br />      break;<br />  }<br />  return $theValue;<br />}<br />}<br /><br />$numtest_Recordset1 = "-1";<br />if (isset($_POST['num_test'])) {<br />  $numtest_Recordset1 = $_POST['num_test'];<br />}<br />mysql_select_db($database_sailing, $sailing);<br />$query_Recordset1 = sprintf("SELECT COUNT(*) as cnt FROM test  WHERE test.num_test = %s", GetSQLValueString($numtest_Recordset1, "int"));<br />$Recordset1 = mysql_query($query_Recordset1, $sailing) or die(mysql_error());<br />$row_Recordset1 = mysql_fetch_assoc($Recordset1);<br />$totalRows_Recordset1 = mysql_num_rows($Recordset1);<br />if($totalRows_Recordset1 == 4) {<br />$error = new tNG_error("Timeslot is filled!",array(),array());<br />return $error;<br />}<br /><br />// Make an insert transaction instance<br />$ins_test = new tNG_multipleInsert($conn_sailing);<br />$tNGs->addTransaction($ins_test);<br />// Register triggers<br />$ins_test->registerTrigger("STARTER", "Trigger_Default_Starter", 1, "POST", "KT_Insert1");<br />$ins_test->registerConditionalTrigger("{Recordset1.cnt} >= 2\n", "BEFORE", "Trigger_Default_FormValidation", 10, $formValidation);<br />$ins_test->registerTrigger("END", "Trigger_Default_Redirect", 99, "_test1.php");<br />// Add columns<br />$ins_test->setTable("test");<br />$ins_test->addColumn("name_test", "STRING_TYPE", "POST", "name_test");<br />$ins_test->addColumn("num_test", "NUMERIC_TYPE", "POST", "num_test");<br />$ins_test->setPrimaryKey("id_test", "NUMERIC_TYPE");<br /><br />// Make an update transaction instance<br />$upd_test = new tNG_multipleUpdate($conn_sailing);<br />$tNGs->addTransaction($upd_test);<br />// Register triggers<br />$upd_test->registerTrigger("STARTER", "Trigger_Default_Starter", 1, "POST", "KT_Update1");<br />$upd_test->registerTrigger("BEFORE", "Trigger_Default_FormValidation", 10, $formValidation);<br />$upd_test->registerTrigger("END", "Trigger_Default_Redirect", 99, "../includes/nxt/back.php");<br />// Add columns<br />$upd_test->setTable("test");<br />$upd_test->addColumn("name_test", "STRING_TYPE", "POST", "name_test");<br />$upd_test->addColumn("num_test", "NUMERIC_TYPE", "POST", "num_test");<br />$upd_test->setPrimaryKey("id_test", "NUMERIC_TYPE", "GET", "id_test");<br /><br />// Make an instance of the transaction object<br />$del_test = new tNG_multipleDelete($conn_sailing);<br />$tNGs->addTransaction($del_test);<br />// Register triggers<br />$del_test->registerTrigger("STARTER", "Trigger_Default_Starter", 1, "POST", "KT_Delete1");<br />$del_test->registerTrigger("END", "Trigger_Default_Redirect", 99, "../includes/nxt/back.php");<br />// Add columns<br />$del_test->setTable("test");<br />$del_test->setPrimaryKey("id_test", "NUMERIC_TYPE", "GET", "id_test");<br /><br />// Execute all the registered transactions<br />$tNGs->executeTransactions();<br /><br />// Get the transaction recordset<br />$rstest = $tNGs->getRecordset("test");<br />$row_rstest = mysql_fetch_assoc($rstest);<br />$totalRows_rstest = mysql_num_rows($rstest);<br />?> <br /> <!-- InstanceBegin template="/Templates/start3col.dwt" codeOutsideHTMLIsLocked="false" --> <br /> <br /> <br /> <!-- InstanceBeginEditable name="doctitle" --> <br /> <br /> <!-- InstanceEndEditable --> <br /> <!-- IE6 dropdown menu fix --> <br /> <script src="/js/nav_main.js" type="text/javascript"></script> <br /> <br /> <!-- InstanceBeginEditable name="head" --> <br /> <!-- InstanceEditableHeadTag --> <br /> <br /> <script src="../includes/common/js/base.js" type="text/javascript"></script> <br /> <script src="../includes/common/js/utility.js" type="text/javascript"></script> <br /> <script src="../includes/skins/style.js" type="text/javascript"></script> <br /> <!-- InstanceEndEditable --> <br /> <br /> <br /> <br /> <br /> <div id="page_wrapper"> <br /> <div id="header_bg"> <br /> <div id="header"> <br /> <div id="logo"> <img src="/images/spacer.gif" alt="Umass Boston" width="68" height="79" border="0" /> </div> <br /> <div id="nav-site"> <br /> <?php include "/home/httpd/html/php/googlesearch_home.php" ?> <br /></div> <br /> <div id="global_nav"> <br /> <?php include "/home/httpd/html/inc/global.html" ?> <br /></div> <!--end global_nav--> <br /></div> <br /> <!--end header_bg--> <br /></div> <br /> <br /> <br /> <div id="main_bg3col"> <br /> <div id="audience_nav"> <br /> <div id="second_nav"> <br /> <?php include "../inc/_sitenav_sailing.html" ?> <br /></div> <br /> <!--end second_nav--> <br /></div> <!--end audience_nav--> <br /> <div id="titlecontainer"> <br /> <div id="title_bar"> <!-- InstanceBeginEditable name="titebar" --> <?php echo $tNGs->displayValidationRules();?> <br /> <script src="../includes/nxt/scripts/form.js" type="text/javascript"></script> <br /> <script src="../includes/nxt/scripts/form.js.php" type="text/javascript"></script> <br /> <script type="text/javascript"></script>$NXT_FORM_SETTINGS = { <br /> duplicate_buttons: false, <br /> show_as_grid: true, <br /> merge_down_value: true <br />} <br /> <br /> <a href="../index.html">Marine Operations</a> <!-- InstanceEndEditable --> </div> <br /></div> <br /> <br /> <div id="main"> <br /> <div id="left_col"> <br /> <div id="navcontainer"> <!-- InstanceBeginEditable name="menu" --> <br /> <?php<br />  mxi_includes_start("_menu.html");<br />  require(basename("_menu.html"));<br />  mxi_includes_end();<br />?> <!-- InstanceEndEditable --> <br /></div> <br /> <!-- end nav_container --> <br /></div> <!-- end left_col --> <br /> <br /> <div id="right_col"> <!-- InstanceBeginEditable name="menuRight" --> <br /> <?php<br />  mxi_includes_start("_menu_right.php");<br />  require(basename("_menu_right.php"));<br />  mxi_includes_end();<br />?> <!-- InstanceEndEditable --> <br /></div> <br /> <!-- end right_col --> <br /> <br /> <div id="main_col"> <!-- InstanceBeginEditable name="title" --> <br /> <div id="titlesection">:: Sailing Program</div> <br /> <h2 class="subheadBlue">Test</h2> <br /> <!-- InstanceEndEditable --> <br /> <br /> <!-- InstanceBeginEditable name="content" --> <br /> <br /> <p class="txt_bluebold">Header</p> <br /> <p>&#160; <br /> <?php<br /> echo $tNGs->getErrorMsg();<br />?> <br /> <br /></p> <div class="KT_tng"> <br /> <h1> <br /> </h1></div></div></div></div></div>
                • 5. Re: Insert validation BEFORE not working
                  Level 1
                  I forgot to mention, in this form, I'm capturing the name_test and num_test text fields. If the same name and number are entered 4 times, then an error should show up, forcing the person to change one or both items and re-submit the form.
                  Thanks again for your help!
                  So close!
                  • 6. Re: Insert validation BEFORE not working
                    Wouldn´t ADDT´s "check unique" trigger be of help in your "if there are 2 or less recordsets with the same time" case ? After all, this trigger is made to compare (definable) transaction values against (definable) table columns.
                    Cheers,
                    Günter Schenk
                    • 7. Re: Insert validation BEFORE not working
                      Level 1
                      Doesn't "check unique key" only work to verify if 1 record with the same data exists?
                      I just tried using checked unique key and put in the two fields and then in the advanced tab put buiilt this condition {Recordset1.cnt} == 2
                      My thinking was that this Build Condition would kick in and when there were two of the same records in the table, when I attempted to insert a third, an error message would show. But it didn't and let a third record in instead of showing an error message.
                      I appreciate your help and know I'm getting closer to making this work!
                      So close!
                      • 8. Re: Insert validation BEFORE not working
                        can be one or more matches, doesn´t matter
                        what about $totalRows_Recordset1 == 2 ?
                        However, your Recordset1 most probably doesn´t pick up the insert/update transaction values, as it maybe doesn´t even grab the $_POST['num_test'] values you think it should, if any -- please remember, the transaction recordset generates an array of values with a variable amount of entries, and $_POST['num_test'] would just be able to grab one value. That said, the whole Recordset1 could be wrong as such.
                        Cheers,
                        Günter Schenk
