9 Replies Latest reply on Sep 12, 2008 4:50 AM by Günter Schenk
    Why is this not working??
      I want return a status after the email was send ( I need this for flash )
      //start Trigger_Custom trigger
      function Trigger_Custom(&$tNG) {
      $status = "send";
      return $status;
      //end Trigger_Custom trigger
      // Register triggers
      $ins__3bit_->registerTrigger("STARTER", "Trigger_Default_Starter", 1, "POST", "KT_Insert1");
      $ins__3bit_->registerTrigger("BEFORE", "Trigger_Default_FormValidation", 10, $formValidation);
      $ins__3bit_->registerTrigger("AFTER", "Trigger_SendEmail", 98);
      $ins__3bit_->registerTrigger("END", "Trigger_Custom", 50);
      I hope dat someone can help me... This is urgent :-(
      greetings
        • 1. Re: Why is this not working??
          Günter Schenk Level 4
          Hi Maikel,
          where is this status message supposed to be displayed ?
          Cheers,
          Günter Schenk
          Adobe Community Expert, Dreamweaver
          • 2. Re: Why is this not working??
            Level 1
            It should be display when the email was send successfully..
            if ($status == "send")
                 echo  "ok";
            else
                 echo "nok";
            • 3. Re: Why is this not working??
              The problem I see is:
              a) once the transction has been executed respectively the emails have been sent, the current page will redirect to another page (e.g. a Dynamic List), and any attempt to "echo" something will at least fail for the current page, and the value of your variable "$status" will be discarded.
              b) if the Send Email trigger has done its job, the email *have* been sent, and you´ll get redirected -- but if Send Email fails to execute for whatever reason, you´ll be getting an ADDT driven error message anyway.
              Well, maybe *I* just don´t get it ;-)
              Cheers,
              Günter Schenk
              • 4. Re: Why is this not working??
                Level 1
                This page get's a POST from flash and is expecting an answer back
                there will be no redirecting at all
                everything is working great except this part:
                echo "ok";
                else
                echo "nok";
                • 5. Re: Why is this not working??
                  will that answer (aka the variable´s value) have to be echoed within the document´s body ?
                  Cheers,
                  Günter Schenk
                  • 6. Re: Why is this not working??
                    Level 1
                    Yes have to bo echoed within the body.
                    • 7. Re: Why is this not working??
                      but wouldn´t the page have to get reloaded for displaying the initially non-existing message ?
                      Cheers,
                      Günter Schenk
                      • 8. Re: Why is this not working??
                        Level 1
                        Hello Günther,
                        The page does not have to be reloaded I just want to echo an send if everything went fine or a not send if the mail was not send.
                        greetings, Maikel
                        • 9. Re: Why is this not working??
                          Hi Maikel,
                          once a page loads, the initially displayed body contents of a regular HTML page (I´m not talking about advanced technics at this point) is all you get. If you want to change a certain part (e.g. the visibility or the contents of a paragraph) of the document on-the-fly and without reloading the page, you´d have to resort to DOM manipulating technics such as "AJAX" which could do that.
                          I understand what you want, but I think that your Custom Trigger (respectively what it´s supposed to do) will not have any effect for several reasons:
                          a) it´s an END trigger which only gets triggered if the previous SendEmail trigger did execute without errors -- that said, if the SendEmail trigger did fail to work for whatever reason and the emails hence could not be sent, your Custom Trigger won´t get executed anyway and is practically useless.
                          b) your Custom Trigger is supposed to return some value in the document´s body -- but without implementing some AJAX routines you just can´t have that on the very same "non-reloaded" page.
                          If you really need to display some sort of "success" status message, I´d suggest to indeed redirect to another page after all and display this message there, because that´s the only reliable way, as this redirection would not occur in case the emails couldn´t be sent respectively the SendEmail trigger failed to execute.
                          Cheers,
                          Günter Schenk
