2 Replies Latest reply on Oct 10, 2008 7:08 AM by (Paul_Taylor)
    Help - strange insert error
      (PHP MYSQL DW9 ADDT)
      Using the table user_usr as a general registration/contact table
      ie users of the site who make contact - but dont want to register - insert there details
      we manually change them to active users with LI and PW if required later
      only form on page inserts into the user table -and doesnt have the login_usr field
      and I get the error
      tNG_fields.getColumnType: Column login_usr is not part of the current transaction.
      for a straight insert (using the ADDT insert wiz) where login_usr is not even on the page
      why do I get this error?
      Notes:
      user_usr.login_usr is not unique in the DB
      it is used on the site login page (and consequentially in the ADDT login prefs)
      (if I add login_usr to the insert transaction - the error goes away - but I don't want any reference to login_usr on the page, so I rather not leave this without knowing what's going on?)
      also getting an automatic unique 6 char password in the password field on every insert (when I include user_usr in the transaction fields) and password_usr is NOT in the transaction or on the page anywhere - MYSQL field is set to unique - didn't think that it created its own PWd's ?
      more info
      it error always echos the field name in the tng_config.inc.php that is used for login name
      ie in THIS case
      $tNG_login_config["user_field"] = "login_usr";
      so it looks like you cant insert into the table that you use for login and password storage
      using the insert wiz or the user reg wiz - if you don't include the user login fields as defined in tng_config.inc.php?
      HELP!
      tia
      Paul
