2 Replies Latest reply on Oct 23, 2008 9:45 AM by (Juergen_Helmers)
    dependent required field
    Level 1
      Hi!
      I have an update page for a record that I did create using the update record wizard. Most fields are required and I have used the easy and great third page of the wizard to specify the required fields and put down custom error messages for the user.
      I have two fields that are only required if the user has checked yes in a radio group which is part of the same form. initially I have tried to put in an if-statement around the requirement definition using the database fields but of course that will not work since the record is only updated if the form has been processed.
      Then I thought I could check on "$_POST['funds'] == 1", where funds is the database field of the radio group to check on. But that will result in a requirement whether yes or no is checked in the radio group.
      Is there a way to check on the users choice in the form and implement this dependent requirement feature?
      Any pointers would be greatly appreciated.
      Cheers Juergen
