10 Replies Latest reply on Dec 2, 2008 7:32 AM by David Wu
    how to get custom trigger result when insert
    David Wu Level 1
      I set a trigger before insert, if the result was $aa = 50;
      how to get $aa?
      it doesn't work
      $ins_testtable->addColumn("t_num", "NUMERIC_TYPE", "VALUE", $aa);
        • 1. Re: how to get custom trigger result when insert
          Depends what $aa is? If it is a locally declared variable you need to declare it as a global variable.
          • 2. Re: how to get custom trigger result when insert
            David Wu Level 1
            you mean like this?
            $GLOBALS['aa'] = 50;
            and then what value should I set in insert transaction?
            • 3. Re: how to get custom trigger result when insert
              David Wu Level 1
              This my code, anything wrong? <br /> <br /><?php require_once('Connections/conntest.php'); ?> <br /><?php<br />// Load the common classes<br />require_once('includes/common/KT_common.php');<br /><br />// Load the tNG classes<br />require_once('includes/tng/tNG.inc.php');<br /><br />// Make a transaction dispatcher instance<br />$tNGs = new tNG_dispatcher("");<br /><br />// Make unified connection variable<br />$conn_conntest = new KT_connection($conntest, $database_conntest);<br /><br />//start Trigger_Custom trigger<br />function Trigger_Custom(&$tNG) {<br />$GLOBALS['aa'] = 100;<br />}<br />//end Trigger_Custom trigger<br /><br />// Make an insert transaction instance<br />$ins_testtable = new tNG_insert($conn_conntest);<br />$tNGs->addTransaction($ins_testtable);<br />// Register triggers<br />$ins_testtable->registerTrigger("STARTER", "Trigger_Default_Starter", 1, "POST", "ins");<br />$ins_testtable->registerTrigger("BEFORE", "Trigger_Custom", 50);<br />// Add columns<br />$ins_testtable->setTable("testtable");<br />$ins_testtable->addColumn("t_name", "STRING_TYPE", "POST", "t_name");<br />$ins_testtable->addColumn("t_num", "NUMERIC_TYPE", "VALUE", "{aa}");<br />$ins_testtable->setPrimaryKey("t_id", "NUMERIC_TYPE");<br /><br />// Execute all the registered transactions<br />$tNGs->executeTransactions();<br /><br />// Get the transaction recordset<br />$rstesttable = $tNGs->getRecordset("testtable");<br />$row_rstesttable = mysql_fetch_assoc($rstesttable);<br />$totalRows_rstesttable = mysql_num_rows($rstesttable);<br />?> <br /> <br /> <br /> <br /> <br /> <br /> <br /> <script src="includes/common/js/base.js" type="text/javascript"></script> <br /> <script src="includes/common/js/utility.js" type="text/javascript"></script> <br /> <script src="includes/skins/style.js" type="text/javascript"></script> <br /> <br /> <br /> <form id="form1" name="form1" method="post" action=""> <br /> <?php<br /> echo $tNGs->getErrorMsg();<br />?> <br /><?php echo $aa;?> <br /> <input type="text" name="t_name" id="t_name" /> <br /> <input type="submit" name="ins" id="ins" value="送出" /> <br /></form> <br /> <br />
              • 4. Re: how to get custom trigger result when insert
                Günter Schenk Level 4
                Hi chan,
                please try with referencing the PHP variable this way:
                $ins_testtable->addColumn("t_num", "NUMERIC_TYPE", "VALUE", "".$aa."");
                Cheers,
                Günter Schenk
                Adobe Community Expert, Dreamweaver
                • 5. Re: how to get custom trigger result when insert
                  David Wu Level 1
                  it's not work
                  Error:
                  SQL error: Column 't_num' cannot be null.
                  Developer Details:
                  SQL error: INSERT INTO testtable (t_name, t_num) values ('test', null). (SQL_ERROR)
                  • 6. Re: how to get custom trigger result when insert
                    it's not work
                    Error:
                    this means that the variable $aa respectively its value is still not detected -- don´t know why this doesn´t work, but the syntax suggested in my previous post is the correct one however, because this is how you need to embed PHP variables within the "addColumn" context.
                    Cheers,
                    Günter Schenk
                    • 7. Re: how to get custom trigger result when insert
                      David Wu Level 1
                      but it's not work, are you succeed?
                      code
                      // Add columns
                      $ins_testtable->addColumn("t_num", "NUMERIC_TYPE", "VALUE", "".$GLOBALS['aa']."");
                      result
                      Error:
                      • 8. Re: how to get custom trigger result when insert
                        David Wu Level 1
                        I tried this one, actually, {GLOBALS.variable_name} is one of mark-up language,I add echo $a this time, after submit, $a appear on the page, so I think "definea trigger" has been executed successfully, but still got error message <br /> <br />http://uploads.screenshot-program.com/my.php?image=upl2682569831.jpg <br /> <br />code <br />-------------------------------------------------- <br /><?php require_once('Connections/conndb.php'); ?> <br /><?php<br />// Load the common classes<br />require_once('includes/common/KT_common.php');<br /><br />// Load the tNG classes<br />require_once('includes/tng/tNG.inc.php');<br /><br />// Make a transaction dispatcher instance<br />$tNGs = new tNG_dispatcher("");<br /><br />// Make unified connection variable<br />$conn_conndb = new KT_connection($conndb, $database_conndb);<br /><br />//start definea trigger<br />function definea(&$tNG) {<br />global $a;<br />$a = 100;<br />}<br />//end definea trigger<br /><br />// Make an insert transaction instance<br />$ins_testtable = new tNG_insert($conn_conndb);<br />$tNGs->addTransaction($ins_testtable);<br />// Register triggers<br />$ins_testtable->registerTrigger("STARTER", "Trigger_Default_Starter", 1, "POST", "ins");<br />$ins_testtable->registerTrigger("BEFORE", "definea", 50);<br />// Add columns<br />$ins_testtable->setTable("testtable");<br />$ins_testtable->addColumn("t_name", "STRING_TYPE", "POST", "t_name");<br />$ins_testtable->addColumn("t_num", "NUMERIC_TYPE", "VALUE", "{GLOBALS.a}");<br />$ins_testtable->setPrimaryKey("t_id", "NUMERIC_TYPE");<br /><br />// Execute all the registered transactions<br />$tNGs->executeTransactions();<br /><br />// Get the transaction recordset<br />$rstesttable = $tNGs->getRecordset("testtable");<br />$row_rstesttable = mysql_fetch_assoc($rstesttable);<br />$totalRows_rstesttable = mysql_num_rows($rstesttable);<br />?> <br /> <br /> <br /> <br /> <br /> <br /> <script src="includes/common/js/base.js" type="text/javascript"></script> <br /> <script src="includes/common/js/utility.js" type="text/javascript"></script> <br /> <script src="includes/skins/style.js" type="text/javascript"></script> <br /> <br /> <br /> <br /><?php echo $a; ?> <br /> <form id="form1" name="form1" method="post" action=""> <br /> <label for="t_name">tname</label> <br /> <input type="text" name="t_name" id="t_name" /> <br /> <?php<br /> echo $tNGs->getErrorMsg();<br />?> <br /> <input type="submit" name="ins" id="ins" value="submit" /> <br /></form> <br /> <br />
                        • 9. Re: how to get custom trigger result when insert
                          David Wu Level 1
                          I think it's a bug, because I tried everything that addt offer to define a value for transaction <br /> <br />value from custom trigger <br />session.aa works! <br />cookie.aa works! <br /> <br />value from form <br />post.aa works! <br />get.aa works! <br /> <br />only globals.aa failed, and I am a hundred percent sure it's impossible caused by typing error, because I only substitute the variable when I tried different approaches <br /> <br />//start Trigger_Custom trigger <br />function Trigger_Custom(&amp;$tNG) { <br />$_SESSION['aa'] = 30; <br />} <br /> <br />to <br /> <br />//start Trigger_Custom trigger <br />function Trigger_Custom(&amp;$tNG) { <br />$GLOBALS['aa'] = 30; <br />} <br /> <br />$ins_testtable-&gt;addColumn("t_num", "STRING_TYPE", "VALUE", "{SESSION.aa}"); <br /> <br />to <br /> <br />$ins_testtable-&gt;addColumn("t_num", "STRING_TYPE", "VALUE", "{GLOBALS.aa}"); <br /> <br />and I do one more test, if I define the variable at begin, it's like <br /> <br /><?php<br />$GLOBALS['aa'] = 30;<br />?> <br /> <br />and it works!! <br /> <br />so, I can't pass the value by define variable in custom trigger...
                          • 10. Re: how to get custom trigger result when insert
                            David Wu Level 1
                            Finally I got a solution, although it's not the best
                            $aa = 30;
                            $tNG->addColumn("t_num", "NUMERIC_TYPE", "VALUE", $aa);
                            // Add columns
