15 Replies Latest reply on Feb 4, 2008 9:36 AM by (Evgenij_Suldin)
    Current monitor recommendations
    Level 1
      I finally need to replace my CRT monitor and (after a lot of reading and not so much understanding) have narrowed my search to 3-4 TFTs, an Eizo CE210W, an NEC 1990SXi or it's cousin SpectraView 1990 or a Quato(graphic) Intelli Color 190. I'd like to continue using my Eye One Display 2 for calibration.
      There's a number of things that puzzle me.
      Is "Hardware-Calibration" mandatory for a banding free calibration? The two NECs fe seem to differ only (apart from the hood) in the SpectraViews ability to be "hardware-calibrated" with the included software. Is it really (physically) doing something different than the cheaper version 1990SXi would do when calibrating it using it's OSD? Both are said to do use "12-Bit LUTs and 12- Bit Gamma Correction (GammaComp)".
      The Quato (at least this one) seems to have a different approach, using a few fine-tuned factory presets instead of whitepoint/gamma calibration. But wouldn't these loosen over the life span of the display? I mean would a D50 2.2 gamma preset still be accurate after three or four years? Some CRTs I've seen would vary a lot in luminance and color balance over time, are TFTs less prone to this?
      The Eizo is using a PVA panel as opposed to the S-IPS panels of the others. What's the difference? I've noticed most higher end displays use some kind of xyz-IPS panel.
      Any hints, input, links etc. appreciated!
        • 1. Re: Current monitor recommendations
          (Andrew_Rodney) Level 1
          The NEC's are superb (at least my 2690 and 2490) and yes, you want to use the SpectraView II software to conduct all the work internally and use GammaComp and ColorComp.
          • 2. Re: Current monitor recommendations
            Ramón G Castañeda Level 4
            Wow! That's high praise from a most authoritative source. I'm archiving it for when my CRTs need to be replaced.
            Thanks.
            • 3. Re: Current monitor recommendations
              Level 1
              Hm... I finally ordered an Eizo CG210-N because I saw one at a good price. Well... basically because I saw one. The NECs are hard to locate around here. Although I've red the criticism about it's color navigator software in another thread here. I had done some reading, the SpectraView Software is actually bassiccolor's display 4 software. I did like display 4 when I tested that a while ago. But is that using more patches for the hardware calibration than Color Navigator does?
              • 4. Re: Current monitor recommendations
                Level 1
                Uhmm...
                'it' refers to the Eizo here of course...
                • 5. Re: Current monitor recommendations
                  Not so, SpectraView II is built by NEC. And the cost with the Colorimeter (aprox $200) is a screaming deal when you purchase with the display. A much better bang for the buck than Eizo.
                  • 6. Re: Current monitor recommendations
                    Level 1
                    Well, i've downloaded the SpectraView Software here:
                    http://www.spectraview.nec-display-solutions.com/license/?oemId=3&language=de
                    This software is called SpectraView Profiler 4.1.6. This looks very very very very exactly like the software "display4" you find at http://www.basiccolor.de...
                    Not that this would make it any worse, of course.
                    Or is this a different software from the one you're referring to?
                    Is there anything that should make me cancel my order on that particular Eizo? (Apart from NECs being less pricey in general?)
                    • 7. Re: Current monitor recommendations
                      This site isn't letting me log in so you might need to send me via email a screen shot.
                      Yes, the really big difference is price here. Eizo may preform better (hard to believe) but until I get actual data from Karl Lang who thoroughly tested the NEC's for this session at PPE* (but wasn't supplied displays for testing by Eizo which could be said to raise a red flag), its not clear what Eizo offers at that extra price point.
                      *http://www.photoplusexpo.com/ppe/exhibit_hall/conference/conference_info.jsp
                      • 8. Re: Current monitor recommendations
                        (Marco_Ugolini) Level 1
                        Andrew,
                        Do the two NEC models (2490 and 2690) offer DDC connectivity as well? By that I mean, does the SpectraView software have direct control over the LCD display's signals during the calibration procedure?
                        • 9. Re: Current monitor recommendations
                          Yes.
                          • 10. Re: Current monitor recommendations
                            Level 1
                            I've send you the screenshots of the interface and the first page of the two manuals. They're in german, but illustrate the 'strong similarity'.
                            You may be right, but I've actually paid less than I would have for the SpectraView NEC of the same size. For what it's worth, I'm pretty satisfied so far. The Portrait function is wonderful!
                            • 11. Re: Current monitor recommendations
                              Its not the same software I'm using. I've sent an email to my guy at NEC to see what and why they are different.
                              • 12. Re: Current monitor recommendations
                                Level 1
                                Perhaps NEC is including a different software in the US?
                                • 13. Re: Current monitor recommendations
                                  Having worked with the Eizo CG241, CG241W, NEC 2690 and 2490 & the Lacie 526.
                                  Money not being an issue, the Eizo CG241W is the Hands down winner here.
                                  No question about it.
                                  If money is an issue, get the Eizo CG241W anyway because your going to be using it everyday and to save a couple hundred dollars for an everyday tool you will be glued to is just foolish!
                                  • 14. Re: Current monitor recommendations
                                    Green Hornet,
                                    did you had a chance to work with the new Samsung XL24 as well?
                                    Ralf
                                    • 15. Re: Current monitor recommendations
                                      Help to rescue the child-
                                      Very urgently money resources are required, translate who how many can on webmoney, perhaps you will rescue a life to our girl!!!!!
                                      Eight years old to Sasha Suldina, our daughter. In 2001 doctors have made it the diagnosis: sharp a blood cancer.
                                      The child has passed chemotherapy in the Moscow regional oncological clinic (Balashikha),
                                      Now is in remission. In January, 2003 have been found out viruses of hepatitises In and With,
                                      That very seriously threatens life of Sasha. Now we find additional financial assets for this purpose,
                                      To have possibility to spend qualitative treatment of hepatitises expensive medicines(these preparations are not included in the list of preferential medicines).
                                      We ask everyone who is not indifferent to the stranger to misfortune, to bring whenever possible the feasible contribution to business of rescue of the girl.
                                      Copies of documents are attached to the letter.
                                      Very much we ask, translate who how many can, probably you will rescue our girl
                                      This letter not a deceit, we Ask the help, a critical situation.
                                      Thanks all who helped, helps or wishes to help, the help to our girl now is necessary.
                                      Then we spent a lot of time with the child on air, walking on wood. After 3 hours of walks Sasha has started to complain of strong weariness and a pain in joints. Have taken temperature. 38,7. The doctor who has suspected a usual sharp respiratorno-virus infection has been immediately caused. Standard antibiotics and warm tea with a raspberry have been appointed. Late at night observed very strong pains in the bottom of a stomach and its pressure (the stomach was «доскообразный»).Fast immediately hospitalised the child in the Central regional hospital of of Balashikha with suspicion on a sharp appendicitis. Emergency operation has been spent, the diagnosis has proved to be true. The peritonitis, an inflammation began. Operation on appendicitis removal has passed successfully. But after operation condition Сашеньки has not improved. The heat (from above 38).В stably kept Every possible analyses of blood, including on rare infectious diseases, have not given results. But viruses of a belly typhus and a salmonella have been found out. Meanwhile a condition of the child promptly worsened. Haemoglobin level was more low 60, the quantity тромбоцитов and лекоцитов has sharply decreased. Donor blood and an intravenous hormone преднизолон was applied. From children's branch of oncology МООД of Balashikha, Svetlana Varfolomeyev has been invited to that moment were зав.отделением which has suspected system disease of blood at the child. Sasha it has been urgently translated in children's oncological branch where the diagnosis «sharp лимфобластный лейкоз» has been exposed, a blood cancer. Pathological бластных cages in a bone brain was more than 96 %.Состояние the child - the hardest. There has been immediately begun antibacterial therapy by antibiotics of a wide spectrum of action, in parallel - massed инфузионная therapy (glucose, физраствор), was applied преднизолон. After a while there has been begun chemotherapy of the sharp period under German report ALL BFM-90.
                                      Always yours, Irina and Evgenie
                                      SULDINA SASHA, 16.12.1996 of the river
                                      It is observed in the Moscow regional oncological clinic (МООД)
                                      (Acceptance date on the account - June, 2001)
                                      The clinic address: 143900 Moscow regions, Balashikha, street Karbysheva, 6, children's branch.
                                      The case record № 6562, an out-patient card - M - 377
                                      Attending physician МООД: Injushkina Evgenie Vasilevna
                                      Managing branch MOOD: Varfolomeyev Svetlana Rafaelevna
                                      The pediatrist on a residence: Меткалова Love Александровна
                                      The inquiry on physical inability: series МСЭ - 011, № 832324, is given out 31.10.01 Main bureaus
                                      медико - social examination on the basis of the Certificate № 538.
                                      (Physical inability is prolonged 13.11.03, the new inquiry: series МСЭ - 2001, № 1090547, is given out 13.11.03 Bureaus
                                      МСЭ Balashihinsky area of the Moscow area on the basis of the Certificate № 4123)
                                      (Physical inability is prolonged 09.12.04, the new inquiry: series МСЭ - 2001, № 5992493, is given out 09.12.04 Bureaus
                                      МСЭ Balashihinsky area of the Moscow area on the basis of the Certificate № 5041)
                                      The pension certificate: № 921810, it is given out by 20.12.02 Management ПФР of Balashihinsky area.
                                      Expensive operation is required, send money and rescue the girl
                                      The scanned copies of documents: http://new.swapfile.ru/files/31402 / % D0%9E%D1%82%D1%81%D0%BA%D0%B0%D0%BD%D0%B8%D1%80%D0%BE%D0%B2%D0%B0%D0%BD%D0%BD%D1%8B%D0%B5 + % D0%B4%D0%BE%D0%BA%D1%83%D0%BC%D0%B5%D0%BD%D1%82%D1%8B.rar
                                      Photos Of Sasha:
                                      http://new.swapfile.ru/files/31403 / % D0%A4%D0%BE%D1%82%D0%BE%D0%B3%D1%80%D0%B0%D1%84%D0%B8%D0%B8.rar
                                      For interested persons to render immediate material aid:
                                      ELECTRONIC PURSES: Transfer by means of system of payments WEBMONEY TRANSFER:
                                      PURSES: USD Z338444558172, EUR E227345040422, RUB R195149635709
                                      WMID: 416818651774
                                      The user (Suldin E. Ju) is certified.
                                      We very much hope for your support....
